2014 Kia Optima
Pull off the rubber along the door.
Pop the rear C panel off. Use a panel puller. The clips can be really tough and can break.
Remove the rear passenger roof handles and dome light. Be careful with the clips that the dome light screws into. They barely fit the hole they are in.
Pull down the headliner and feel your way to the 3 clips holding down each rear corner and the middle of the headliner. Again, use a panel puller.
You'll now see the bolt that holds the roof fin. Use a 19mm wrench or socket to remove the nut.
Pull the antenna wire down. And squeeze the little clips on either side of the threaded portion of the antenna to remove the fin.
