1 - 1 of 1 Posts
2013 Optima/K5 LX (Spicy Red)
Found these on Amazon by LZLRUN and they will customize the lights with your image. Very similar to my other post about the courtesy lights, I used the same transparent image to order these. They are rechargeable, stay lit for a good while, and are sensitive to motion to extend the life of the charge. They also have many colors to select, and can be solid or in the "breathing" mode. I do recommend using a napkin or something over them when placing a cup on top as the condensation can cause it to stick to the bottom and you don't want to have them later fall off the bottom of the cup and wonder where they dropped. I charge mine about once every two weeks.
1 - 1 of 1 Posts
