I am fully aware of the different types of fuel injection.......and that to REALLY clean the Intake valves on a GDI engine, you need to strip it down and use a mechanical process.
Which is a fairly ridiculous expense if you don't have any real issues with the engine.
True. An Italian tune up won't work on its own but, following the treatment, CRC recommends a run at "highway speeds". And my highway speeds can be quite "brisk"
And, FYI, there are also video's out there showing the CRC treatment removing large chunks of valve grunge. But you really won't get them spotless using it, just a bit cleaner.
We still get a regular 34mpg highway on ours and 22 around town. It runs great but the idle was a little lumpy, so I decided just to check out the TB for cleanliness and also run a can of CRC through the system while I was at it. And, afterwards, I noticed there WAS an improvement in the idle and it smoothed out. Given the issues with the Theta II engines, I use Valvoline Synthetic 5w30 and Kia/Hyundai filters and change it every 3500 miles. So far, all the UOA's came back as normal and I hope that the sample I send off to Blackstone today comes back the same......
For the first 5 years, we used the Optima as a road trip car but, since we bought our Grand Cherokee, we now use it as our local runabout with the longest trips being 65 miles each way to San Antonio Airport. It has been as dependable as a hammer........using no oil between changes.
