1 - 6 of 6 Posts
2014 sx turbo
So I found in a pick and pull lot, a complete turbo kit on a 2011 SX. I just bought an EX and I’m wondering can I do a full swap with the ECU if I have all the components and if so what components do I need outside of the entire intake inner cooler exhaust manifold turbo coil packs ECU? They are literally only wanting to 240 bucks for all of the items listed above. And I am working on getting that price even lower if I give them all of my working components as well will this work?
I would appreciate a super quick response being as if someone else sees that this is there I will lose these things and I don’t want to so I’m literally thinking about going and getting it all tomorrow if it’s possible.
2014 sx turbo
But I just got a new block put in my optima . So So even with the inner cooler in the entire turbo charger system in the ECU coil packs of that stuff it’s still won’t work?
Compression ratio different, as well as engine strength for 18 psi boost.
Not as easy as one may think, so better off purchasing a turbo car or buy the entire drive-train, wiring, inter-cooler etc and convert yours over, a lot of work.
If I remember correctly even some of the trans ratios are different.
2014 sx turbo
Ok thank you. I will return the inter cooler amd get credit for the black Interior I’m snagging
1 - 6 of 6 Posts
