Hey guys so started having the low voltage to wastegate issue on my SX. Watched some vids and read the threads, but still having an issue. When I was moving the actuator all the way to the right as I saw in the vids, I could only go as high as 4.01v. But I notice when I move it over the rod does seems to skip/jump a little bit its not smooth (not sure if it should be) so wondering if I should order the new actuator. I turned the rod end counterclockwise a turn or turn and half. It did seem to make it better for a couple drives but its back to going limp every time after you give it heavy boost.
Ran it a bit and measured it again after sitting a while earlier and measured the same. Not sure If Im missing something or just need a new wastegate. Thanks for any input
