2018 Optima JF 1.7CRDi
Is the TPMS from a 2019 Sportage compatible with a 2018 Optima?
I've found some 19" wheels which comes from a Sportage, but I am unsure if the TPMS is compatible or not.
Any help is appreciated, Thanks
If you look it up in the Kia parts catalog, the 2019 Sprtage is only compartable with the Cadenza, but they are the same frequency as the Optima 433 mhz. Checked aftermarket and both take the same sensor, so you should be good to go.
Years ago, even if the sensors were the same frequency, the individual sensor ID's needed to be uploaded into the system for them to work, same now ?????
