Flip open the key and push it up into the slot under the door handle, that will pop the cover off and give you access to the key hole to unlock the doorsI'm curious as to how I can gain entry into the car if the keyless entry doesn't work. I know there is a hidden keyhole but I dont know how to remove the cover. I tried with the key but had no luck.
Flip open the key and push it up into the slot under the door handle, that will pop the cover off and give you access to the key hole to unlock the doors you have to press hard
