I was wondering if the hole cavity on the OEM 17x7.5 wheels be deep enough for a 15mm spacer for the wheels to be flush with the hub. Or do I have to run a 20mm. Couldn't find an answers. Thanks.
Not certain as to what you're asking, but a 15mm spacer needs to be a hub-centric adapter as the studs aren't long enough for a flat 15mm spacer (slightly thicker than 9/16") to leave enough threads for the lug nuts. If you want to see what a 15mm spacer would yield, place washers/nuts over 2 opposing studs the thickness of 15mm (actually .59"), then place the wheel on to see if it's where you want it to be.
