I think it is the dual clutch system. Seems like I read one clutch is used for gears 1,3,5, and 7, the other clutch is used for Reverse and the even numbered gears. In reading, seems like one clutch engages from a stop or near stop for 2nd gear and reverse. If you go slow enough or are at a complete stop, then the "other" clutch engages or activates? If this is correct, my 2nd gear and reverse clutch is fine and smooth. The other clutch for 1st gear engagements shudders some of the time. More so when the engine is cold and has been sitting over the weekend. Sometimes it clears up and acts fine. Usually it is pretty good once the car is warmed up. I swear I have noticed a difference, meaning it can be better, if in Eco or Sport mode, at times. So I can't exactly tell if it is software/programming or an actual physical problem with the clutch, such a a warped pressure plate? Go find a good uphill slope, stop on the hill, put selector in manual position so it won't shift, and do multiple uphill starts in 1st gear. See what it feels like. Usually mine is warmed up by then and is not bad. But pulling out of a slight uphill in my driveway in the morning can be hideous and jerky. Seems worse because the engine is not warmed up yet and isn't running as smoothly as clutch engages. If you figure out how to get Kia to do something about it, let me know! Seems like all the service people are clueless unless an error code or whatever is detected when they hook it up to the computer. I guarantee if they had a clutch vibration sensor, mine would throw a code almost every morning!
