Hello all,
2016 Optima LX FE here. I can’t get the TPMS light to stay off. After starting the car, the light flashes, then stays on. I have continuously adjusted the tire pressure, setting all 4 tires at 34 PSI. If the light comes on while driving, I stop and check the pressures; they’re usually 38-39, which I think is normal since the tires are hot at that point. Any suggestions will be great.
Hello all,
It's not rare for the batteries inside the TPMS sensors to only last 5 years. May need to replace all 4 TPMS sensors.
I might go ahead and have them all replaced. I used a scan tool earlier and I had codes for all 4 sensors that said something like, radio frequency channel failure.
Think it's pretty rare to have all 4 go bad at the same time though so there may be something wrong with the TPMS receiver module or the programming. If it was me i would still change the sensors and go from there.
