Has anyone swapped a 2016 or newer 2.4 engine into a 2014 car? It seems the cam sensor is different and the vvt sensor is moved but will the newer engine work? They are much cheaper then direct replacement
Since I dont have shell 93 available to me, I need to use petro canada ultra 94 which may contain up to 10% ethanol.
Is this enough to cause carbon build up?
Hope you can help me, good people of Optima Forums :)
Few weeks ago I started to hear rattling sounds in my 2017 Optima PHEV -- it happens every other time that I break, video here: photos.app.goo.gl/Gs4GYFhY2N8Zzphw8
Dealership said they'll charge $250 diagnostics fee, before they can tell...
Put a catch can as soon as I got my new engine and it fills up so much quicker. With the older engine it filled up half way after about 8k kms.
Now....full to the rim only after 2k km!!
Good thing I checked.
I have 2014 Kia optima Platinum
Vin # KNAGN417ME5502400
Engine # G4KJEH127547
Recently i noticed the blue smoke from the exhaust and engine oil level goes down. My mechanic is expecting that may be the Seal are leaking which consuming engine oil. Is there anything i can do, Can Kia will replace...
