1 - 10 of 10 Posts
So I'll make this pretty short and simple. My Power Steering, ABS, TCS, Low Tire Pressure, and Check Engine lights all came on at the same time. The steering got a lot looser and my powered brakes didn't work either. Weirdest thing is, it only happens half the time? I'll struggle to drive to lunch and when I get back into my car it's perfectly fine... but 30 minutes or so later all the lights will come back on. Any Ideas what the problem could be? Or if it would be covered by a recall? Edit: I believe it could be a faulty wheel speed sensor, but I'm not sure.
Speedometer Vehicle Trip computer Odometer Tachometer
https://www.reddit.com/r/kia/comments/qomn0r
Did you have your alternator/battery checked? Any codes thrown? Year, engine, mileage?
Engine is currently blown. Thinking of getting a new one installed but if this is gonna cost more than the car is worth then there's no point in replacing engine. I'm not sure about alternator but I've never had a battery light pop up, nor any battery related problems, so I'm thinking it's either sensors, a computer, or a wiring issue. 2014 Kia Optima EX 96-100k miles.
1 - 10 of 10 Posts
