61 - 80 of 91 Posts
2015 KIA Optima
Finally got them installed. Had them on for about a week already. Over all I love them except the turn signal portion, because the light color is a little faded or should I say not as deep amber or whatever color it is, compared to the regular turn signal. Maybe its just my OCD :cry:.
But here are some pictures. :10: (P.S. be sure to ask K5OptimaStore for the pdf of the modification you need to do. To make them fit flush)
(I also made a post about my install, might be some help to you)
Discussion Starter · #62 ·
They look amazing! Thank you for posting pics for us as well! How long did the install take you?
2015 KIA OPTIMA
It took me two days, only reason is because I ran out of wire and I had to go get some more the next day. but other than that it would of been 1 day.
Mine took about 2-3 hours. I prewired the fog lamps to accept a 3 pin connector and used a relay. Probably would be faster if I just used posi taps to keep everything simple.
Sent from my Nexus 5 using Tapatalk
2015 KIA Optima
yea same here, it took me a little long because I added a switch to the inside of the car. I also soldered just about everything. I also Used conduit added connectors to most things, for the future if I ever have to take them off or replace them. The thing that took awhile was removing the bumper because I was scared of cracking the bumper like other have mentioned.
2015 KIA OPTIMA
Once you get used to removing the bumper it'll take you less than 15 minutes to remove. My wife actually timed me the other day and it took me about 10 minutes to remove lol
Discussion Starter · #68 ·
Thank you both for sharing your experience in terms of how long it took, I take it you both also did it on your own as well?
2015 optima kia optima
ok I really want these and want to attempt to install them myself. I dont want/care if the turn signal part of it doesnt work. my question is if i just connect the 2 other wires will this work with the stock fog light switch? and if i were to wire them up like this with the LED color be amber?
2015 KIA OPTIMA
You can wire then directly to your fog lights. You just have to tap them because they are bare wire.
depends what wire you give power to.
there are 3 cables
White - White leds
Yellow - amber leds
black - GND for both
so if you just want amber just connect yellow and black cables and if you want just white, connect white and black.
thank you jery911 this is the info i needed
Discussion Starter · #77 ·
Yep this is correct, you simply do not connect the turn signal wiring and they will remain white.
and the LED color will remain white ?
there are 3 cables
White - White leds
Yellow - amber leds
Yep exactly, thank you for breaking that down.
61 - 80 of 91 Posts
