2013 kia optima
So my car is pretty loose in the front end, over bumpy roads. Ive decided to change preassembled struts, my question is what all should I change on the front end. I'm looking at besides struts, front sway bar links, lower ball joints, and outer tie rods. But should I go crazy and do inner tie rods and lower control arms? I also plan on changing rotors and pads, maybe even front wheel bearings or hubs. Any thoughts, thanks in advance.
2013 kia optima
Discussion Starter #2
So since no one responded I ended up changing the lower control arm, strut, outer tie rod and end link on each side. Made a big difference, I still have sway bar bushings to change but at this point I'm done.
