Been a while, but to get the caliper bracket off you'll need to remove bolt from the suspension and move the arm. Probably caliper, but those sliders stick continuously so see how the piston moves inward when caliper removed. I got sick and tired of the crappy setup and replaced all 4 calipers with aluminum units and new brackets/ hardware.
Also when trying to press the piston inward, if it doesn't go in easily, open the bleeder and try again. If it still doesn't move, caliper, but if it moves easily, brake hose.
