About 1.5 months ago, I started having issues with my brake lights being on after I exit the car and accelerator cutoff because the brake lights are on while im not touching the brake lights. Recently, its been getting horrible. I usually pressed the brake to temporarily get rid of the issue, but recently the accelerator cutoff has been horrible, so ive been pushing the brake pedal backward. I already knew what the issue was, he little brake pedal stopper pad. Yesterday, I got a replacement at autozone. I put it in and it was a little too big. I couldn't put the old one back in since it was broken, causing all of the issues. I put the large one in and immediately, since it was too big, i had to press the brake pedal harder in order to go into reverse or drive, and to activate the brake lights. I went home, parked it overnight, and this morning I bought a brand new brake pedal stopper pad from the Kia dealership. I had to press the brake pedal hard, because the car was off, but i put the new pad in and everything turned on electrical wise but the engine did not start. I thought it was just the battery, so since my battery has died on me multiple times because of the brake pedal issue, i had a portable jump starter. I tried using it, and still, nothing. I jumped the car and still, didn't crank. So, I charged the battery and it didnt work, so I went to autozone and the guy told me the battery was dead. He told me something about the battery and cranking, and told me it was a dud. $209 later, I had a new battery. I rushed home, connected the terminals tight AND....... the car still did not start. I have everything electrical working. Headlights, dome lights, radio, horn, ac fan and the car does not crank at all. I do hear little clicking in the engine bay, but no start.
I have tried
- Pressing the start button once, then holding it for 10 seconds
- Using my other key fob
- Inserting the key fob into the glovebox location
- Swapping/Check fuses
- Cleaned battery terminals
- Putting the car into P and D and putting it back into P
- Starting in N
and it still does not start. I only hear clicking under the engine bay. It wont even attempt to crank. Has anyone ran into this problem? Besides the accelerator cut off and brake light issue caused by a deteriorated rubber piece, the car was running absolutely great before this all happened. Any tips or advice would be appreciated! It's a 2013 Optima EX GDI
