Looking to rewire my fogs as drl with turn on power for relay from parking lights. Is there some where in cabin I can splice from rather than at the parking lights themselves? This way an just t-tap and I not be exposed to elements.
Want from parking light circuit as don't want the fogs lit when starting the car or while parked. If some one could direct wire location and color that would be appreciated.
Thanks!
Negative parking lights can be found at the headlight switch. It's pink in a white 13 pin plug, pin 1. To reach it, you must pop off the steering wheel shroud. In order to use this, you will need a relay to turn it into a positive signal.
If you want positive parking lights, it can be found in the dash fuse box, and each side has an individual wire. They are both in a black 39 pin plug, pins 11 and 24. The wire colors are green/black (L); brown/black (R).
Thank you! I ended up tapping it at the headlight harness itself though as I did the mod before your reply. Have disabled high beam drl and fogs come on with parking lights. Just waiting now on delivery of 3000k led bulbs
Why would you want DRLs? They make no sense, and only offer a false sense of security when driving, when what they really do is turn you into a road hazard.
That's quite an unique point of view. How can one have better lighting during the daylight hours when the lights are off????????? Maybe I'm missing something.
Because of the brightness needed during the daylight hours, DRL's are to go off or dim when the headlights are on, and must say that during the day I see the DRL's even in bright daylight.
For LTVs, DRL effects were progressively higher with crash severity and the effects were all positive. It seems that DRLs were more likely to reduce LTV involvements in daytime target Two-PV crashes.
DRLs seemed to reduce the LTVs’ involvement in daytime target crashes by 5.1 percent. The effect was borderline statistically significant at the 0.05 level.
A majority of the European studies consistently found that a DRL law was associated with a reduction in crashes. The effects varied from 4 percent to 27 percent depending on crash type, crash severity, season, roadway conditions, and light conditions. The DRL effects found in the U.S. studies were less consistent and more uncertain.
Sparks’ 1993 study20 which examined Canadian government fleet data found that DRLs reduced twilight, two-vehicle crashes by 15 percent. The effect was statistically significant. Two reports produced by Transport Canada also showed positive DRL effects. Of these, Arora et al.21 concluded in 1994 that DRLs significantly reduced daytime two-vehicle opposite direction crashes by 8 percent. Tofflemire and Whitehead22 in 1997 reanalyzed the Canadian DRL law and found that DRLs reduced opposite direction and angle crashes by 5.3 percent. The result was also statistically significant.
I know that for motorcycles, they are required to keep the headlight on for making other drivers more likely to see the oncoming motorcycle, because without the headlight the bike just disappears into the background.
Related Threads
Kia Optima Forums
520.8K posts
42.3K members
Since 2010
