1 - 8 of 8 Posts
Hi everyone. I go by Joecorvair. My wife's car is the Kia. It has almost 150k miles and luckily has been a very good reliable car and passed the engine recall test. Recently it has been making a short growl / snort noise when accelerating from a stop. I listened to it with my wife pressing the gas with the brake and it sounded like was in the intake area. I could feel a vibration that felt like the sound was in the silencer in the intake hose. I took the hose off and shook it and nothing. Then I took off the air filter cover and it rattled when I shook it. The carbon looking filter that says "do not remove" was a little loose so I put some rubber sealant in the corners (not on the air filter seal area) and after it dried put it back together and voila no noise!
Hope this helps someone. I saw a forum question from earlier this month that sounded like the same issue but I could not post because I'm new here.:)
2017 Tesla Model X
Hi Joecorvair, welcome aboard to the Optima Forums!
Wow that is a a lot of mile for the 2013 Optima EX.
Glad to hear it's running like a champ, and thanks for the tip.
-David
Thank you for the heads up, I posted earlier on what seems might be the same thing. I will check on it this week end!
Well, I took my whole intake apart and cleaned the throttle body while I was at it. My system had no carbon filter in the air cleaner box and nothing ratteling. Everything looked great, put it back tougether and still have that snorting noise at initial throttle and again it is more pronounced when the AC is on. Last week I was in the Home Depot parking lot and I heard another LX making the same noise?
OMG Problem found... this noise has baffeled me for a while now. Could not figure it out and finally took it to the dealer under extended warranty and after talking to the tech to explain how and when the noise would appear, it turned out to be the tensioner pully for the surpentine belt. I pride myself on working on my cars my whole life and I did not get this. Harmonics?? I swear it sounded like an intake issue. :rolleyes:
1 - 8 of 8 Posts
