1 - 8 of 8 Posts
I have a 2011 kia Optima that cranks over but wont start. I first started off by making sure it had gas because it had been sitting for a while. I then make sure the gas was pumping to injectors by loosening a hose a quickly put the key on and off position. I then checked the spark plugs and they were a little dirty so I cleaned them and still no spark. Can some please 馃檹 help me out and try and point me in the right direction. Thank you all
old/bad gas?
Did you check that you are producing a spark? Looking at the plugs is not enough, you need to verify there is a spark being generated, and if not, can figure that out specifically.
old/bad gas?
I put fresh gas in but not familiar with how to check if theres spark. How would I check that? Thanks for replying and your help
I'm no expert, but I'd like to suggest something much simpler to check. Did you have the battery checked? That's the first thing that came to my mind when you mentioned it was sitting awhile.
What was the result?
1 - 8 of 8 Posts
