Hi everyone,
I just bought a 2004 Kia Optima for my daughter. When we took it for its inspection, it failed for OBDII. The computer would not communicate with the diagnostic tool. I then took it to the DMV and their tool did not connect either.
In looking at various forums, I can't find anything similar.
There are no problems with the car running and no warning lights are on.
We did pull a fuse for the sunroof, so could it be that since that fuse is missing, the computer is in some sort of "suspension"? The car also has an after-market radio, and I have heard that may be an issue?
Any help would be greatly appreciated.
Thanks!
Josh
As the OBDII has power, there must be a circuit protector, so try replacing the fuse for the sunroof, and if no go, check other fuses.
Welcome to the Optima Forums Josh, glad to have you with us here.
This particular forum is dedicated to the 2011-2020+ Optima models.
While you're more then welcome to search around here, you may not find what you are looking for.
This forum below is dedicated to the 2001-2006 Kia Optima Magentis (The year you have) and you might have better luck there.
Either way, hope you are able to get it figured out soon.
-David
K5 Optima Store
