21 - 37 of 37 Posts
01/2015 ROTM, 05/2015 ROTM
2013 Optima 2013 SXL
Discussion Starter #23
I think the SXL already had these...
No, they have a single cylinder caliper.
---------- Post added at 05:39 PM ---------- Previous post was at 02:14 PM ----------
Great review of how they're still working out for ya! How much for the "Julian, make them for Jason" pair? :D
Probably cheaper to buy a BBK!!!!.....;)
Discussion Starter #27
Julio Kia have you tried mounting the spare donut, does it clear the caliper?
I never had a spare !...I have all my air-ride equipment back there.
2016 Kia SX
I had to "clock" (rotate) the brake lines where they attach to the calipers, but re-used the stock lines without issue.
2015 KIA Optima
And did you use the brake line bolt from the original or used the new one that came with the 2 piston calipers. Btw how are you liking them so far? Is it really worth it or am I wasting my time.
2016 Kia SX
I simply disconnected the OEM lines from the OEM calipers and attached them to the XG350 calipers. I didn't know the car that well when I put them on, but after driving other cars, I get back in and notice the feel is really increased. It will depend on your choice of pads, of course. If you plan on putting dustless, high-mileage type pads in there is no point to this mod. My EBC redstuffs are okay; they make dust like an Oklahoma dust storm but it hauls down when it needs to. I plan on tryin G-LOC pads next with even higher hopes for the performance. I also added speed bleeder bleed nipples while I was changing the claipers so bleeding is a one man affair going forward :cool: Be sure to use a good quality fluid and change it "regularly" (I change my brake fluid and trans fluid more than called for; cheap maintenance).
2015 KIA Optima
Thanks! I plan to go with the Brake Pads Julio Kia mentioned. https://www.amazon.com/dp/B000C1Q6PA?tag=vs-auto-convert-amazon-20
what do you think about those?
2016 Kia SX
Depends what you're after. Those look very "OEM" to me. My EBC redstuffs dust like an S.O.B but feel stronger than stock which I prefer. Each to their own. I passed 7 cars closer to the end of a 'T' intersection of a highway than I thought it was this summer, and my passenger said "I get why you upgraded your brakes but not the power, now.".
Will these calipers work on my 2015 LX? I read thru the post and didn't see anyone say yes or no.
Thank you Allen
2016 Kia SX
Thank you Allen
I would suspect no. I think only the SX and SX-L have the larger front rotors which match these calipers.
Thank you Allen
The XG350 caliper setup will fit 2014-2015 models. However you will have to get the larger SX rotors. Cross-referenced the part numbers for those years and they match up.
21 - 37 of 37 Posts
