1 - 6 of 6 Posts
Is there any difference in catback exhaust between 2.0 and 2.4? I'm looking to demod and go to stock.
Edit: looks like the flange is different, but it may just be bolt hole spacing that is easy to adjust?
The aftermarket supplier will send the correct flange with the kit. It is a very long cat back. I have the Magnaflow cat back for my 15 2.0 SX-T and I love it. It actually goes all the way up to the back of the engine. It connects to the midpipe. somewhere up there.
I can pick up another 20 hp if I bought a new mid pipe with a catalytic converter. that way plus my Lap3with 22lbs of boost instead of factory 17lbs. ....but no matter what you do you will LOVE the sound of a new CAT-BACK. GOOD LUCK MAN!!! (y)
Its the bolt hole spacing which many people have easy drilled out. As long as you dont have a 2011 Korean version.
1 - 6 of 6 Posts
