Wheel/Tire Size and Offset. Combo's known to work.
Page 1 of 11 123 ... LastLast
Results 1 to 10 of 106
Thread: Wheel/Tire Size and Offset. Combo's known to work.
    Moderator Avant's Avatar
    Orange County
    1,401
    There has been a ton of threads lately about what wheels will fit, what offset works etc. I know its hard to find in the wheel/tire thread as a lot of them are just pictures.
    I am going to start this thread so people can post What wheel size, tire size and offset they are running and works. (also if you are lowered or not.)
    I will update the first post as much as I can.
    PLEASE DO NOT POST IN THIS THREAD WITH QUESTIONS OR COMMENTS. SPECS ONLY TO KEEP THIS CLEAN. I will delete any other post.
    Format like this.
    [SIZE=3][B]20-Inch Wheels:[/B][/SIZE]
    Avant's Setup:
    Wheel Size: 20x9 front and rear
    Wheel Offset: ET 40 front and rear
    Tire Size: 235/35/20 front and rear
    Suspension: Ark Lowering springs
    Rubbing: none at all[COLOR=#333333]
    [/COLOR]Avant's Setup (wider tires):
    Tire Size: 245/35/20 front and rear
    [/COLOR][COLOR=#333333]
    Unreligion's setup:
    [/COLOR]Wheel brand/Model: MRR HR10
    Wheel size: 20x8.5 Front 20x10 Rear
    Wheel offset front: 35 front 40 rear
    Tire Brand/Model: Nitto Neo Gen
    Tire size: 225/35/20 front 245/30/20
    Suspension: D2 coilovers / rolled fenders and trimmed fender liners and maxed neg camber on camber plates in the front. Negative camber rear via stock adjustments
    Rubbing: some rubbing while turned hitting bumps on and high speed bumps rubs fender liners / still no rubbing on the back with neg camber adjustment[COLOR=#333333]
    Thor's Setup
    Wheel Size: 20 x 8.5 front and rear[/COLOR][COLOR=#333333]
    Wheel Offset: ET 35[/COLOR][COLOR=#333333]
    Tire Size: 245/35/20 front and rear[/COLOR]
    Suspension: 1/2" drop up front only
    Jorand's Setup:
    Wheel brand/Model: TSW Nurburgring
    Wheel size: 20 x 8.5, front and rear
    Wheel offset: ET40
    Tire Brand/Model: Nitto NT555
    Tire size: 245/35/20 front and rear
    Suspension: Stock
    Phife's setup
    Wheel seze:20x9.5
    Offset: ET 40 Front ET 38 Rear
    Tire Size: 235/30/20
    Suspension: D2 Coilovers (need adjustable camber for this set up)
    Rubbing: none with adjustable camber setup.
    Nappydrew's Setup:
    Wheel Size: 20x8.5 Front & Rear
    Wheel Offset: ET 38
    Tires: 235/35/20
    Suspension: Stock
    Rubbing: NEVER
    Unreligion's setup:
    Wheel brand/Model: KMC Rockstars for cars
    Wheel size: 20 x 8, front and rear
    Wheel offset: ET40
    Tire size: 225/35/20 front and rear
    Suspension: D2 coilovers / rolled fenders and trimmed fender liners in the front
    Rubbing: some rubbing while turned hitting bumps on and high speed bumps rubs fender liners / no rubbing in the back
    kawarthaoptima's setup:
    Wheel Size Front: 20x8.5
    Wheel Offset Front: ET 35
    Front Tires: 225/35/20
    Wheel Size Back: 20x10
    Wheel Offset Back: ET 43
    Back Tires: 255/35/20
    Suspension: Stock
    Rubbing: NEVER
    ckyder's setup:
    Rims: Verde Parallax [COLOR=#333333]
    20x9.5, 20x10[/COLOR][COLOR=#333333]
    Offset: ET 35, 45[/COLOR][COLOR=#333333]
    Tires: 245/35/20[/COLOR][COLOR=#333333]
    Suspension: D2 coilovers[/COLOR][COLOR=#333333]
    Rubbing: Never,(Little camber in the front and back)[/COLOR]
    [SIZE=3][B]19-Inch Wheels:[/B][/SIZE]
    XSWPxEX setup:
    Avant Garde M310 Dolphin gray
    19x8.5 +35 Front and Rear
    245/35/19
    Megan springs
    No rubbing at all so far.
    Ashpian's Setup:
    Wheel Brand: ACE Alloy Mesh-7
    Wheel Size: 19x8.5 (front & rear). ET 40
    Tire Brand: Cooper Zeon RS3-A
    Tire Size: 245/40/19 (front & rear)
    Suspension: Eibach Pro Springs (revised)
    Rubbing: Slight inside driver front when fully locked to the left. Happened before being dropped though.
    Ride Quality: Close to stock SX on all but harshest bumps. Rides very good IMO. Handles corners fantastic now with virtually no body roll. Will update after they settle if this changes.
    Richysh's Setup:
    Front wheel size : 19X8 et 35
    Front tire size : 225/40/19
    Rear wheel size : 19X8.5 et 35
    Rear tire size : 245/35/19
    Suspension : Eibach springs
    So far, no rubbing
    Trbotime's setup:
    Wheel Size: 19x8 front and rear
    Tire Size: 245/40/19 front and rear
    Suspension: Stock
    Rubbing: None
    Bhom920's setup:
    Front wheel size : 19X9 et 45
    Front tire size : 245/35/19
    Rear wheel size : 19X9 et 45
    Suspension : Eibach Sonata springs
    No rubbing
    Sixteen's setup:[COLOR=#333333]
    Wheel brand/Model: Avant Garde M310[/COLOR][COLOR=#333333]
    Wheel size: 19 x 8.5, Front and Rear[/COLOR][COLOR=#333333]
    Wheel offset: ET 35[/COLOR][FONT=arial][COLOR=#333333]
    Tire size: 225/40/19, Front and Rear[/COLOR][/FONT]
    Suspension: Ark Springs[FONT=arial][COLOR=#333333]
    Rubbing: Never had any rubbing[/COLOR][/FONT]
    Keviny182's setup"
    [COLOR=#333333]Wheels: Avant Garde M310[/COLOR][COLOR=#333333]
    Size: 19x9.5 et40[/COLOR][COLOR=#333333]
    Tires:235/35/19
    [/COLOR]Suspension: ark springs[COLOR=#333333]
    No rubbing at all[/COLOR]
    Royce118's setup:
    [COLOR=#333333]Wheels: [/COLOR]Vossen CV5[COLOR=#333333]
    Size: [/COLOR]19X8.5 et40 Front and Rear[COLOR=#333333]
    Tires:[/COLOR]245/35/19
    Suspension: stock springs[COLOR=#333333]
    CIn60ragfk's Setup:
    Wheels: Tsw Mallory 5
    Sise: 19x9.5 et 40
    Tirs: 235/35/19
    Suspension: megan springs
    no rubbing
    MDJammin's Setup on Sonata:
    Volk GTS
    19x9.5 et43 Front
    19x9.5 et 43 + 20mm Spacer Rear
    235/35/19 Hankook V12's
    D2 Coilovers
    Front stock camber - Clears fenders - Inner lower rim lip rubs lower control arm only turning left at full lock
    Rear requires -4* camber - Fenders rolled out 3mm to avoid damage
    Rear Notes - Tire is still fully on ground, camber wear is present but not extreme, driving alone it hardly ever rubs, add one person OR a full tank of gass and it rubs occasionally, add a 3rd person it rubs just from hard acceleration, 4th person is NOT doable.
    Nikko's setuo:
    Wheels: Gen Coupe R-spec wheels
    Wheel size front: 19 x 8 | ET30 | 225/40/19
    Wheel size rear: 19 x 8.5 | ET30 | 245/40/19
    Suspension: Megan Springs 1.5" all around.
    So far no rub. Even with 200lbs (old wheels and other junk) in the back.
    [SIZE=3][B]18-Inch Wheels:[/B][/SIZE]
    Evil mechanic's:
    Wheel Size: 18x 7.5 front and rear
    Wheel Offset: ET 31 front , 26 rear
    Spacers: 15mm front, 20mm rear
    Tire Size: 225/45/18 front and rear
    Richysh's other setup:
    Wheel Size: 18x7.5 all around, OEM luxury touring wheels
    Offset: ET 26mm all around with 20mm spacers
    Tire Size: 225/45/18 tires
    Suspension: Eibach lowering springs
    no rubbing
    Thor's Setup[COLOR=#333333]
    [/COLOR][COLOR=#333333]Wheel Size: 18 x 8 front and rear[/COLOR]
    [COLOR=#333333]Wheel Offset: ET 42[/COLOR]
    [COLOR=#333333]Tire Size: 235/50/18 front and rear[/COLOR]
    [COLOR=#333333]Suspension: 1/2" drop up front only
    [/COLOR][COLOR=#333333]Rubbing: none at all[/COLOR]
    YESITSAKIA's setup
    Privat Akzent
    Wheel Size: 18x8.5
    Offset: 30
    Tire Size: 245/40/18
    Suspension: Eibach's
    No rubbing at all
    KiaOp2012's setup:
    Wheel brand/Model: TSW/Jerez
    Wheel size: 18 x 8, front and rear
    Wheel offset: ET35
    Tire Brand/Model: [SIZE=1][SIZE=1][SIZE=1][SIZE=1][SIZE=1][SIZE=1]Vredestei[SIZE=1]n S[SIZE=1]essanta[/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE]
    Tire size: 225/45/18 front and rear
    Suspension: Eibach Pro-Kit
    Rubbing: No Rubbing
    [URL="https://www.optimaforums.com/forum/5720-cuorenero.html"][B]cuorenero[/B][/URL]'s setup:
    Wheel brand: Enkei RSF5
    Wheel size: 18x8 (front and rear) 40 offset
    Tire brand: Falken 912
    Tire size: 225/45/18 (front and rear)
    Suspension: Stock
    Rubbing: No
    [SIZE=3][B]17-Inch Wheels:[/B][/SIZE]
    [SIZE=3][B]16-Inch Wheels:[/B][/SIZE]
    2015 Kia Optima SX-L 20x9 Forgestar F10's, ARK lowering springs
    2002 Audi A4 Avant w/ 2.0 Stroker, JE 83mm pistons, I.E rods, GT3071r turbo, methanol injection etc
    https://www.optimaforums.com/forum/8...nown-work.html
    DIY: Lowering Springs Installation
  2. The Following 2 Users Say Kudos to Avant For This Useful Post:
  3. Remove Advertisements
  4. #2
    OptimaForums Veteran richysh's Avatar
    Greensboro NC
    2,308
    K5
    SX Prem & Tech
    19" Genesis Coupe wheels
    So far, no rubbing as of yet but the rear is really close. It seems like if I have the car loaded down, I might rub. I rubbed with 245/40/19 in the rear when I had three people with like 50 lbs of cargo in the car. Not sure with 245/35/19 yet though.
    2012 Kia Optima SX Tech & Prem Touring Pkg. Satin Metal/Black 75k miles, purchased 01/07/2012
    - BTRCC 2.0.4 93 Oct Tune
    - SX-L LED DRLs
    - LED switchbacks
    - 28% tint all around, 20% sunroofs
    - Carbon Fiber 3.0 badges
    - Avital 5303L Remote Start
    - Automatic mirror fold module
    - 19" Niche milan m137
    - Nameless downpipe&midpipe
    - HKS SSQV4
    - Custom made intake made by Dysan911
    - D2 Coilovers
    - 14pc stiff rings
    - Red rear LED turn signal with resistors
    - Red footwell LEDs
    - Red painted calipers
  5. #3
    Bazinga!
    Sep 2011
    1,961
  7. #4
    340
    [B][SIZE=3]19-Inch Wheels:
    [/SIZE][/B]
    No rubbing, might be able to squeeze a 255/35/19 tire
    GONE! 2012 SX : Sonata Eibachs : Bremmerkraft 19x9 : 20% tint
  8. #5
    Learner's Permit Trbotime's Avatar
    North County, S.D.
    260
    19-Inch Wheels:
    Suspension: Stock
    Rubbing: None
    2016 Optima Hybrid EX
    SnowWhitePearl
    Mods to come!
    GONE: 2012 Kia Optima Hybrid
    Snow White Pearl
    19x8.5 Ace Alloy Convex ~ Titanium
    245/40-19 Achilles ATR Sport
    B&G S2 Sport Springs-1" Drop
    Black 3D K Emblems
    20% Tint
    Led's
  9. #6
    Greensboro NC
    2,308
    K5
    SX Prem & Tech
    Oh one more.
    et 26mm all around with 20mm spacers
    225/45/18 tires
    no rubbing
    - SX-L LED DRLs
    - LED switchbacks
    - HKS SSQV4
    - D2 Coilovers
    - 14pc stiff rings
    - Red footwell LEDs
  10. #7
    Learner's Permit Thor's Avatar
    May 2011
    150
    [COLOR=#333333][B]20"[/B]
    [COLOR=#333333]Wheel Offset: ET 35[/COLOR]
    [COLOR=#333333]Tire Size: 245/35/20 front and rear[/COLOR]
    [COLOR=#333333]Suspension: [/COLOR][COLOR=#333333]Eibach Pro[/COLOR][COLOR=#333333]
    [/COLOR][COLOR=#333333]Rubbing: none at all...at least not yet.[/COLOR][COLOR=#333333]
    [B]18"[/B]
    Jan 2013
    Stanislaus County
    12
    [B]20" [/B]
    Wheel offset: ET40
    Suspension: Stock
  12. #9
    Jun 2012
    Mobile, AL
    340
    Privat Akzent
    18x8.5
    30 Offset
    Cooper RS3-A
    245/40/18
    Eibach's
    No rubbing at all
  13. #10
    Dec 2012
    225
    EUROTUNERZ5
    Ace Alloy Convex (Concave) Wheels
    20x8.5 et35 front
    225/35/20 front
    20x10 et45 rear
    245/35/20 rear
    ARK Springs
    So far no rubbing (haven't installed them yet hehe)
    *i will update the post once installed to confirm but I can assure you all these will fit flawlessly
  14. Remove Advertisements
  1. Tire size
    By 1stopoptima in forum Optima Wheels, Tires and Suspension
    Last Post: 02-01-2013, 12:10 PM
  2. wheel/tire size and clearance questions
    By robinson in forum Optima Wheels, Tires and Suspension
    Last Post: 10-30-2012, 12:11 PM
  3. Tire size
    By AgentCooper in forum Optima Wheels, Tires and Suspension
    Last Post: 08-02-2012, 02:24 PM
  4. Official Wheel and offset thread
    By aznboi128 in forum Optima Wheels, Tires and Suspension
    Last Post: 04-20-2012, 05:40 AM
