[DIY] : Door Reflector LED mod, Let there be light! - Page 10
Page 10 of 10 FirstFirst ... 8910
Results 91 to 95 of 95
Thread: Door Reflector LED mod, Let there be light!
  1. #91
    Learner's Permit Optima718's Avatar
    Apr 2013
    Queens NY
    224
    Quote Originally Posted by DINO2K View Post
    My set up are different than yours and mine is connected to the dome light because I wanted to have that fade. Have you try that blue wire around the harness? That's the same wire that most of us used to upgrade our door mood light, I have connected a few wires to that blue wire and it works fine.
    Sent from AutoGuide.com Free App
    I haven't tried the blue wire, i will give that a shot and see if it corrects the issue. The blue wire is a constant power?
  3. #92
    OptimaForums Veteran DINO2K's Avatar
    T.O
    4,405
    SX 2.0T
    Quote Originally Posted by Optima718 View Post
    Actually it's only on when the parking light are on, it's the same wire we used for door catch and mood lighting which is only on when parking light are on. Hopefully that will fix your issue. GL.
  4. #93
    Apr 2013
    Queens NY
    224
    Thank a lot Dino tried the blue wire and it worked perfectly 👍🏼
  6. #94
    T.O
    4,405
    SX 2.0T
    Awesome, glad you have figured it out and your very welcome!!
  7. #95
    Lot Attendant john`stamos's Avatar
    North Carolina
    476
    What is confusing? It's pretty well detailed step-by-step. You can tap both wires from the door sill but there is no reason to run two wires through the door to the car just to get a positive wire.
  8. Remove Advertisements
  1. Can anyone in Ga do the LED door handles mod?
    By crystaljukebox in forum DIY Projects
    Last Post: 04-07-2013, 06:19 PM
  2. [WTB] : Used KIA OEM red led L and R door sills for a mod project on my SX
    By Krazy PR in forum Classified Forum
    Last Post: 01-07-2013, 11:55 AM
  3. Rear Bumper LED Reflector Light Lamps
    By My13OptimaSXL in forum Interior and Exterior Modifications
    Last Post: 09-18-2012, 05:49 PM
  4. [FS] : Optima K5 LED Light Door Scuff Plate & K5 LED Cup Holder
    By PRO1024 in forum Classified Forum
    Last Post: 09-05-2012, 08:25 PM
