[EX-T] : Changed Spark Plugs - noticed some oil
Results 1 to 3 of 3
Thread: Changed Spark Plugs - noticed some oil
    May 2019
    3
    Question Changed Spark Plugs - noticed some oil
    Hey all,
    So I changed spark plugs on my Optima 2013 Turbo. I used the NGK 1422, and I can definitely notice a pretty big improvement on both throttle response and Fuel Economy. Heck, my idling RPM went down to 800-1000 RPM (from 1200 or so).
    Anyway, this was my first time changing spark plugs myself, and I'm a fairly new DIYer as well. So here's the question.
    After removing the ignition coils to gain acces to the plug, I noticed a very minute amount of what seemed like oil on the rubber surrounding the coil. Once I removed the spark plug, it also seemed like the threads on the old plugs also has some small amount of oil on them. Is this normal - if not what could be the reason? I didn't see any obvious leaks (from a very quick visual inspection).
    Thanks!
    Certified Wrench Monkey
    896
    Very unusual that changing spark plugs would cause a lower idle, better throttle response along with better performance, a combination I have never seen. Having said that, oil accumulation in that area could be due to a leaking valve cover gasket.
    Oct 2013
    Hamilton, ON
    220
    Quote Originally Posted by Tetsukei View Post
    Hey all,
    Thanks!
    Call your dealer and ask. I would assume its a dielectric lube(think thats whst they call it) around rubber and anti seize on threads of plugs.
  1. [SX-T] : Changed OEM spark plugs for HKS M45XL...
    By williamhood in forum Optima Engine and Technical Discussion
    Last Post: 12-17-2015, 09:07 PM
  2. [FS] : Got some Spark Plugs for sale
    By MDJammin in forum Classified Forum
    Last Post: 11-21-2013, 10:10 PM
  3. [SX] : Spark Plugs Question
    By C172SPilot in forum Optima Engine and Technical Discussion
    Last Post: 04-29-2012, 11:18 PM
  4. Please check spark plugs on your hyrbid
    By remltr in forum Optima Hybrid
    Last Post: 03-07-2012, 10:01 AM
  5. Spark plugs on Optima engine
    By kiaman in forum Optima Engine and Technical Discussion
    Last Post: 08-27-2010, 01:43 PM
