90k Maintenance
Results 1 to 3 of 3
Thread: 90k Maintenance
    Jul 2015
    25
    Kia Optima
    2014 Kia Optima EX
    90k Maintenance
    Hey guys,
    Just got my car serviced at 90k and they listed a bunch of additional work to get done. Its listed as coolant ($130) Brake fluid ($110) Air filter ($56) Drive Belt ($220)... Seemed a bit much so I opted not to do any of it. I'm not much of a car guy but I figure I can do the air filter, brake and coolant.
    I'm assuming its just a simple top up? or do they actually drain it first and then put brand new fluids in? I'll probably just pay to get the drive belt done.. seems complicated.
    Went on my service manual and it said Dot 3 and Dot 4 works for the break fluid. Is there a specific brand that someone recommends?
    For the coolant it says mixture of antifreeze and water and ethylene base? I have no clue... hahah, could someone also recommend a product?
    For the air filter, it seemed pretty easy to change the cabin and engine filter from a couple videos I saw. Going for a K&N filter and see how that goes.
    and yeah any tips and recommendations would be greatly appreciated !! 🙂
    PS. Driving a 2014 Kia Optima EX
    Thanks in advance !
    Jul 2015
    25
    Kia Optima
    2014 Kia Optima EX
    Oh here's the info from the service manual and the invoice from kia
    Attached Thumbnails Attached Thumbnails 90k Maintenance-20190413_232004_1555271886279.jpg   90k Maintenance-20190414_120736_1555271920145.jpg
    Certified Wrench Monkey
    839
    Brake fluid should be changed every 2-3 years, and it's a lot more than topping off the master cylinder. It requires removing the fluid from each caliper and keeping the master cylinder filled so as not to run dry. Get DOT 4
    Coolant, just a drain and refill. I use generic (Peak) that is listed as replacement for all automobiles.
    Air filter, get an aftermarket paper filter, forego the K&N & high price.
    Also an aftermarket cabin filter.
    Take a look over on RockAuto for desired parts.
  1. 90K mi status report
    By jleebiker in forum Optima Hybrid
    Last Post: 04-11-2015, 10:05 PM
  2. Maintenance Minder 2012 EX-T
    By CeruleanBlue in forum Optima General Discussion
    Last Post: 12-16-2011, 11:44 AM
  3. Turbo - Oil Change Maintenance Notification Fix on the Way!
    By WA SX in forum Optima Engine and Technical Discussion
    Last Post: 10-03-2011, 12:06 AM
  4. Online Kia maintenance parts
    By philbytx in forum Optima Engine and Technical Discussion
    Last Post: 04-13-2011, 10:23 PM
