Engine vibration when A/C is on
Results 1 to 7 of 7
Thread: Engine vibration when A/C is on
    Mar 2019
    Question Engine vibration when A/C is on
    Hello,
    I have 2015 Kia Optima with 2.0 Hyundai Nu Engine.
    When car is Idle and A/C is on, engine vibrates a bit. Not so much vibration but my old Toyota doesn't have that problem. Is that normal?
    I also noticed that RPM does not increase when A/C is on at idle. RPM is at about 650RPM to 700RPM at idle and A/C is on (and engine is already warm).
    A/C is cool though, doesn't have any problem. Just wondering if that is normal vibration and if RPM should increase when A/C is on?
    Thanks!
    Senior Wrench Monkey
    909
    The A/C compressor is a variable displacement compressor, which means it's always operating and has no clutch to kick on and off. If you hear the engine change at idle, it's probably the cooling fan on/off operation, but the cooling fan creates quite a bit of force when operating, so maybe this is what you'll feeling/hearing and the RPM would remain normal.
    I would think that in your area the compressor would be the same as our US models, but we don't have Nu engines, but as yours was replaced because of no cooling at idle, a normal problem with the VDC. Actually the electronic control valve goes haywire in the back of the compressor.
    Mar 2019
    Thanks @Turbonut! So I guess it is pretty normal vibration then. It doesn't bother much but I though it is worth asking.
    Service center said the problem is at what they called "Control Bar" which is attached in the compressor and they took it out to show me. They said that is usually the cause of the problem. But they replaced whole compressor just to make sure since it is still under warranty.
    I guess A/C compressor is common problem with KIA because I see quite alot of cars with A/C failing at service center everyday.
    909
    Actually a control valve, and yes common problem with Hyundai/Kia.
    Example:
    https://www.ebay.com/itm/FITS-2011-K...-/201991818300
    Sep 2018
    Pioneer, Ca
    29
    2018 Optima EX
    Quote Originally Posted by Turbonut View Post
    So if the compressor is always turning, how much drag is this putting on the engine when you don't have the A/C or defroster engaged?
    909
    Not much drag at all. To simplify the internals, with no a/c called for, the direct drive compressor is just turning, virtually no drag, and when needed, the piston stroke becomes longer, but at highway speeds the compressor once again is just working easily.
    Take a look on the internet to get more familiar with the VDC.
    Mar 2019
    It is actually quite interesting and good to understand how a part of your car works.
  10. Remove Advertisements
  1. Turbo Maintenance ; Excessive Tappet Noise/ Engine Vibration?
    By TRMVOC in forum New Member Introductions
    Last Post: 08-13-2016, 10:11 PM
  2. Engine vibration @2k RPMs in park
    By Evil Mechanic in forum Optima Engine and Technical Discussion
    Last Post: 10-11-2014, 03:24 PM
  3. wobble at low speed and heavy vibration at hwy speeds
    By Yattak07 in forum Optima General Discussion
    Last Post: 12-12-2013, 08:03 AM
  4. Engine Vibration on '12 2.4L
    By oldmanatee in forum Optima Engine and Technical Discussion
    Last Post: 09-22-2012, 10:48 PM
  5. [LX] : Front End Vibration - Axle issue
    By wjones691 in forum Optima General Discussion
    Last Post: 09-11-2012, 11:53 AM
