Transmission rough shifting issue
Results 1 to 8 of 8
Thread: Transmission rough shifting issue
    18
    OPTIMA
    So my wife's Optima SX has gone through about 3 weeks of rough shifting (hard shifts both up and down, staying in lower gear and high rpms etc). I read about the transmission temp sensor and how it could possibly be bad and causing this issue.
    It finally threw a code after about 3 weeks of rough shifting: P0711. So I brought it in to the dealer today. I tried to get them to order the sensor prior to appointment stating that the "P0711" code CEL was lit, but they absolutely refused.
    So diagnosis, mechanic thinks that sensor is OK but there is a pin on the harness that is bad. So they are ordering a new harness/connector. I'm kind of skeptical on the "bad pin" theory...
    Has anyone had this issue resolved with their rough shift transmission issue?
    Jul 2015
    137
    2012 Kia Optima Lx
    Lx
    That exact same thing happened to me. Water somehow got in there and corroded a few pins.
    18
    OPTIMA
    OK. I feel better. Thanks for posting Frank!
    18
    OPTIMA
    so I finally got the transmission fixed. Said they tightened the bolt on the harness and replaced the sensor. Filled the trans with fresh fluid.
    So the next day my wife tells me the backup camera is not working. WTH! I'm wondering if the camera wiring runs through the harness that the tech tightened up or he may have possibly removed some wiring to do the repair and didn't reconnect. I mean what are the odds of the camera going bad RIGHT after the repair?
    Anyone else have the backup camera fail?
    Nov 2015
    Chicago
    34
    Optima SX
    Yes I have had a camera replaced there is a known issue with them in high humidity climates.
    Jan 2017
    cypress, california
    31
    kia
    kia optima
    gdi
    man, I have only had my optima a few days and all these posts are scaring the crap out of me.
  9. The Following User Says Kudos to lamothe1 For This Useful Post:
  10. #7
    Riding Lawn Mower Joreskin's Avatar
    Borden, Ont
    43
    I'm having the same issue with rough shifting for a few weeks and then the check engine light coming on today. I'm going to borrow a code reader to get the error code.
    My question is: If it is a temp sensor, why does it cause the rough shifting?
    2012 Santorini Blue SX Fully Loaded
    TSW Nurburgrings 18 x 8.5 35mm offset
    Nokian WR 225/40 R18 on stock SX rims(Winter)
    Mods:
    - Debadged "Optima" and "SX"
    - Red calipers
    - Flying K all around
    - SRT-4 BOV
    - DIY Led Door Handles
    - Brake Flasher
    - LED Interior
    - LED Reverse
    - 17% tint on back windows
    - 35% tint on front windows
    Senior Wrench Monkey
    996
    Temp sensor will cause very rough shifting, as like many items on the Kia, it's a known failure item. Cheap and fairly easy to replace. Most just replace the sensor, but I believe the Hyundai replacement comes with the harness that at times goes south, but requires a little more work.
    I thought my transmission was going to drop out of the car when cold as the trans was erratic and harsh to say the least, but after warm up it was fine. Funny part is that never had a problem until the KSDS update was performed and the car acted up within 1 mile from the dealership, but of course their response was that nothing they did would have caused the sensor to go bad. Naturally, I couldn't prove otherwise, so swallowed hard, bit my tongue and replaced the sensor, good to go until the next item self destructs.
  12. Remove Advertisements
  1. [ALL] : Transmission shifting points...
    By Alexis in forum Optima Engine and Technical Discussion
    Last Post: 06-06-2016, 10:38 AM
  2. Possible Transmission Shifting Issue
    By Kozentov in forum Optima Engine and Technical Discussion
    Last Post: 05-16-2015, 02:01 AM
  3. Shifting/Acceleration Issue in 2012 Optima Turbo?
    By Optima4Life in forum Optima General Discussion
    Last Post: 04-19-2014, 12:48 PM
  4. 2011 Optima Ex Turbo shifting issue
    By ehowells in forum New Member Introductions
    Last Post: 08-23-2012, 06:31 PM
  5. anyone else having issue w/early auto shifting in manual mode?
    By kevinr14094 in forum Optima Engine and Technical Discussion
    Last Post: 03-29-2012, 07:14 PM
