[LX] : A/C compressor noise / knock
Results 1 to 6 of 6
Thread: A/C compressor noise / knock
    Feb 2014
    New york
    3
    optima
    I have a 2013 Optima LX with the 2.4 motor. Has anyone experienced a knocking noise that seems to be coming from the A/C compressor? When the A/C is off , the car sounds like a diesel engine at low rpms , usually under 1,000. When i turn the A/C on , the noise goes away. I changed the idler pulley and the belt tensioner. Also with the accessory belt removed , there is no noise at all. The noise also goes away after a couple of minutes of driving.
    27,846
    2017
    Tesla
    Model X
    P100D
    Hmm, haven't heard of this before. Wonder if the compressor itself is starting to fail.
    I take it you most likely are no longer under warranty to have the dealer take a look at it?
    OptimaForums Veteran
    1,070
    Just an fyi-When you turn the a/c off, the compressor internals are still turning as this compressor is unlike the "old" units that had a clutch. The VDC on my car made quite a bit of noise all the time, then when the solenoid went bad I replaced the compressor with a relatively new used unit (20k miles).
    I would think if it made noise, it would make it all the time, especially under a heavy load. Will need to do some research.
    Feb 2014
    New york
    3
    optima
    Also at idle with the A/C off or on , the noise isn't there. When i put the car in drive , A/C off , and the rpms decrease , the noise is there. Once the rpms go back up its gone.
    JasonS's Avatar
    Indianapols, IN
    3,398
    EX 2.0
    and you've checked for a slipping belt? And perhaps replace the other idler pulley?
    Dynojet: 294 whp/305 torque/24lbs boost with a custom BTR tune with full bolt-ons.
    2012 Optima EX-T Spicy Red Showroom https://www.optimaforums.com/forum/4...-showroom.html w/ the following MODs: 845 Motorsports FMIC|845 Motorsports 4" Intake|845 Motorsports Charge Pipe|Nameless Midpipe|Nameless Downpipe|Synapse V3 BOV|BTR Custom Tune|Magnaflow Exhaust|Saikou Michi OCC's|Ultra Racing FSTB|kSport Coilovers|R1 Concepts rotors|and MORE...
    1,070
    Check tensioner. Remove the serpentine belt and check all the pulleys, tensioner and idlers.
  9. Remove Advertisements
