Where should the coolant temp gauge sit?
Results 1 to 6 of 6
Thread: Where should the coolant temp gauge sit?
    Nov 2012
    15
    I thought the coolant temp gauge suppose be in the dead center, but on my new car it has always been a little off the center (to the left).
    In the VW I previously drove, the only time it looked like that was when the thermostat was leaking.
    Is this the normal position for Kia Optima? Thanks.
    I'm attaching the photo for illustration.
    Attached Thumbnails Attached Thumbnails Where should the coolant temp gauge sit?-dsc_0148.jpg
    OptimaForums Veteran bumpercut's Avatar
    1,391
    Which engine? If it's the 2.4 GDI, then that's exactly where mine sits. Car seems to heat up very quickly, and also cool down quite fast. Must be all that aluminum in the engine.
    Feb 2012
    Indianapolis
    699
    My 2.0 has a different gauge cluster but it too has always been a little to the cool side of the middle even in 100+ deg days this summer. If it ever got to the middle, I'd be concerned.
    Former Administrator Munky's Avatar
    Cicero, IN
    6,908
    2011 K5 Turbo
    SX W/Premium
    Perfectly normal. I have the SX, so it looks a bit different, but it's still just off center. According to my dashhawk, it fluctuates between 189°F and 199°F during normal operation.
    2011 K5 Turbo - KDM Registry #0009 - Check out helpful links here - links.kok5o.com
    10/2012 + 11/2013 ROTM unreligion's Avatar
    May 2011
    Cedar Park, Texas
    4,445
    2011 2.4L
    my 2.4 sits right about there always
    Driver's License SYMAWD's Avatar
    342
    Mine is always just shy of center as well.
  9. Remove Advertisements
  1. Coolant Levels
    By Camaroguy in forum Optima Engine and Technical Discussion
    Last Post: 09-30-2016, 12:33 AM
  2. Florida sun + Heatshield + 15% tint = big temp difference
    By yaucalabi in forum Off Topic Discussion
    Last Post: 06-18-2012, 08:17 PM
  3. climate control cold air before engine temp rises.
    By Dave H. in forum Entertainment: Audio, Navigation, and Electronics
    Last Post: 12-06-2011, 12:34 AM
  4. HID Temp Question
    By unreligion in forum Optima Appearance and Body Modifications
    Last Post: 11-30-2011, 09:16 PM
  5. Coolant Leak
    By Camaroguy in forum Optima General Discussion
    Last Post: 11-06-2011, 10:53 AM
