'12 SX Navi to Aftermarket Head Unit Conversion (Complete)
Results 1 to 2 of 2
Thread: '12 SX Navi to Aftermarket Head Unit Conversion (Complete)
    56
    Yet another thread on converting NAVI to aftermarket HU
    Climate Controls
    First, the easy part, you can replace the NAVI control with dual-automatic climate control form Ebay and it's completely plug in play.
    I pulled out the Navi HVAC. It is a "QF T-GDI" Model. I have a 2012 SX made in Georgia.
    There are 4 other auto-climate control models with screen that i found on ebay with matching harness plugs
    97250-2T100 - "TF CDP" Version numbers in single digits
    97250-2T101 - "QF CDP" Version 18
    97250-2T110 - "TF CDP" Version 12
    97250-2T110 "QF T-GDI" version 15
    I figure i should stick with QF and found 2T101 cheap so i bought that one, although the 2T111 would've probably been from the non-Navi SX based on the description.
    Also, see my earlier post
    Headunit
    I went with a Pioneer W4400NEX, which is a 7" Dual-Din with Wireless (or wired) Carplay and Android Auto.. It has GPS hookup, Sirius Hookup (via adapter), dual USB (one for Android one for Apple), and requires speed, parking brake, and reverse (for rear view camera) leads.
    Dash Kit
    I went with Metra 95-7345B
    Pros - Cheap, the external piece matches well enough. You don't have to take off the gauge cluster, just remove a single screw to pull it out, because the head unit goes in first, and then the plate.
    Cons - the brackets are plastic and flimsy. I had to shim the headunit a bit with double sided tape on the bottom because it sags a bit because of weight. Because it's a 2-piece, the alignment/depth of HU to trim is little bit annoying. Maybe this carav 11-191 would work better as it's once piece, but you will probably need to pull more of the gauge cluster to get the radio in there.
    Sirius, GPS, Antenna
    For AM/FM there are 2 car-side antenna connectors, one one is plug and play, the other does not get plugged in. FM/ HD Radio works fine, i didn't'test AM.
    For GPS, you can either use included Pioneer GPS receiver dongle, or adapt the stock GPS lead (yellow cable, purple connector) to Pioneer AVIC-F to FARKA cable. I went with adapter.
    For Sirius, for my head unit you needed a Sirius Car Kit SXV300. You can use the included Sirius antenna, or adapt the stock Sirius connector (Farka) to Sirius box (SMB). I used this adapter Maestro HRN-ANT-SAT1
    Harness
    This is where the things got annoying. HYBL-04 and HYKIA-01 is no longer available. The new "complete" harness is AX-HYKIA1-SWC. You also need the SPDIF converter for stock amp AX-HYKIA-SPDIF which is plug and play for this harness.
    The harness is pre-wired, and has outputs for Parking, Speed and Reverse. It also has retained accessory power which our cars don't do (turn off car, radio plays until a door is open). It's also wired for a couple of different configurations (amp and no amp).
    What worked - the sound portion worked fine - follow instructions to connect SPDIF module, and match the harness cables to head unit cables. Illumination and power did too.
    What didn't work - the harness did not properly provide reverse and parking brake signals for me, which per Axxess support is "Because maybe your car model doesn't have it on the CAN bus" and were no help. Steering wheel control functionality also did not work until i manually flashed the unit. Finally, the fact that there are so many wires (most of which unneeded) tightly wrapped made it difficult to modify. With that in mind, i don't recommend it, and recommend looking at a different manufacturer for Steering Wheel controls and SPDIF conversion, a Metra 70-7304 or ebay-alternative harness (get a 2nd for extra pins) and just wiring everything manually between the car harness and head unit harness with necessary outputs for SPDIF. If you're buying a spare harness, get the same manufacturer (ie if using AX-HYKIA1-SWC, get a metra harness) because while the connectors are the same the pin style (how the pin is held in the connector) may be different.
    NAVI Wiring Diagram
    Connector A
    Connector B
    Adapting Harness to NAVI & Pioneer
    For reverse, you need to connect the HU reverse signal to Connector A, Pin 9 (I reused Connector B Pin 2, by pulling the pin, and cutting the cable on the Axxess side)
    For parking brake, i used AX-TRIG1 so i don't have to search for parking brake signal. Wire as instructed (accessory, amp turn-on wire, and ground)
    For Power Antenna - Pioneer does no have a lead for it, so i wired it into the amp turn on lead, along with actual amp turn on wire and parking brake bypass
    For Microphone - buy a 2.5mm mono cable, cut it, and connect Connector B Pin 10 to Positive/inner wire on the 2.5mm, and Pin 22 to Negative. This is where a spare harness with pig tails comes handy as you can just pull the pins + wires from spare and insert them into the Axxess harness for easy connectivity.
    For Reverse Camera Power - you need AX-CAM6V. I wired the 12V "Reverse" wire to the accessory so that camera always gets power. For ground, you need to connect the AX-CAM6V Ground, Car Ground (either use ground wire on harness, or add a pin for connector B pin 23, which is also ground) and camera power ground (connector A, pin 4), which is wired as a speaker output on the Axxess harnes so i just re-used the wire. Finally, connect the AX-CAM6V Camera Power wire to Connector A Pin 11 (it's also speaker wire on the Axxess)
    For Reverse Camera Video - buy a video RCA cable, cut it, and connect Connector A, pin 2 to positive/inner wire, and Connector A pin 3 to negative-outer wire. On the axxess side, these are non-amped speaker wires so you can cut and splice to the RCA.
    AUX and USB
    ON the Navi, the USB cable is separate 4-pin cable from the NAVI that stays separate on the bottom aux/usb module. This cable works - Axxess AX-HYKIAUSB-2 but my pioneer head unit would error disable the USB port if i used it the cable. I think the aux/usb module is the culprit as there's a circuit board there.
    I just ran 2 usb extension cables on the side. Since the head unit is wireless, you don't really need to use those cables much.
    EDIT: Sound Quality
    I'm having some sound distortion issues at higher levels from left and right dash speakers. The Pioneer needs to be cranked up pretty high volume wise at normal listening volumes, and adjusting source level (which meant to match source levels to radio) adds more distortion. The interface does not mention a gain control unlike HYBL-04 and HYKIA-01. I'll see what support says.
    EDIT: Sound Quality Update
    The pot on the side of the interface does in fact make the system louder/adjust gain, even with spdif module. I recommend cranking it up to max clock-wise. Fixed my sound issue distortion from cranking the volume too high up on the headunit. The pot adjustment is back in documentation on AX-HYKIA3-SWC (for newer MY cars). Would be nice if it was documented from the get-go.
    My Complete Harness:
    Complete Install:
    Jul 2013
    West Los Angeles
    26
    Nicely done and great write up! Thank you
  4. Remove Advertisements
  1. Software update for Navi head unit
    By Waynerm002 in forum Entertainment: Audio, Navigation, and Electronics
    Last Post: 08-26-2015, 04:37 PM
  2. [SX-T] : New owner of '12 SXT. Already replaced head-unit! and found a gps locator in fusebox?
    By acemonster in forum Entertainment: Audio, Navigation, and Electronics
    Last Post: 10-05-2014, 09:13 PM
  3. [SX] : QUESTION - Please HELP! Aftermarket Head Unit on 2013 SX w/ Infinity Premium Non-Navi
    By 0235SS in forum Entertainment: Audio, Navigation, and Electronics
    Last Post: 07-12-2014, 03:36 AM
  4. where to "snag" the reverse wire and brake wires for aftermarket head unit install
    By anomaly65 in forum Entertainment: Audio, Navigation, and Electronics
    Last Post: 07-02-2014, 11:05 PM
  5. Replies: 0
    Last Post: 12-12-2012, 03:24 PM
