Car Struggle
Results 1 to 10 of 13
Thread: Car Struggle
    Riding Lawn Mower Steve B's Avatar
    Mar 2019
    22
    Car Struggle
    I'm not sure what the title of this post should've been but, I was hoping you guys might have some insight as to what this might be. I've noticed, multiple times/random times, the car struggling to go from a stop. Most of the time, its noticed when letting go of the brake pedal and the car begins to move on its own in the small time before stepping on the accelerator. I'd like to describe it as its chugging for a second or two before it all settles and the car takes off. It doesn't always happen.
    I will add this bit of information as well (not knowing if it has any relevance to the above topic but, just in case....)
    When I first put gas in the car, I put "regular unleaded". The car struggled with going a LOT of the time but, not always. There was a very noticeable delay in vehicle response after stepping on the accelerator. If I tried sport mode, the issue was almost negated completely. Well, the next fill up, I put in premium or super unleaded with the 92 octane rating. The change in behavior and take off was almost night and day. It's take-off performance is pretty much normal now except the above mentioned topic.
    Anyway, that's what I have going on. I'm considering taking it to a dealer for potential warranty issue. He "warned" me about my new wheels/tires as not being factory spec. I went from 16" 205/65/16 to 17" 225/50/17. I told him, I only got these wheels/tires the day before and this issue was happening long before that. He said, his techs would mention the wheels but, if they can see the acceleration issue isn't tied to tires/wheels then I should be ok.
    I wanted this community's input on what they think it might be. =)
    OptimaForums Veteran
    Chicago, IL
    1,456
    What year make and model do you have?
    BlueSXTurbo's Showroom
    2011 Kia Optima SX T-GDI
    Mar 2019
    22
    Quote Originally Posted by BlueSXTurbo View Post
    2017 Optima FE/LX
    1,524
    How many miles are on your spark plugs?
    If you haven't tried before, this is really easy and just takes about 10 minutes: pull one of the spark plugs and look at it. If it looks good, pull the other three and make sure they look good too.
    Also make sure the engine air filter is not clogged.
    Mar 2019
    22
    Quote Originally Posted by KingFatty View Post
    Well, I only have 12000 miles on the car.
    Learner's Permit Unit ZER0's Avatar
    Aug 2016
    Based out of a Top-Secret bunker in an undisclosed location
    259
    Exclamation
    Also, when was the last time you had an induction cleaning?
    A fuel treatment is not enough, as the fuel injectors are inside the cylinders, so any added fuel treatment will not remove the gunk that will build up on the intake valves.
    Once you get them properly cleaned, install a catch can to reduce the frequency you will need to apply that service.
    At 12000 Miles if you have not had an induction cleaning, you *NEED* one.
    ZER0
    Mar 2019
    22
    Quote Originally Posted by Unit ZER0 View Post
    That’s probably what it is. I’ll be checking into getting that done within the next couple of weeks.
    Lot Attendant
    NorCal
    437
    Dumb question--does the Kia dealership offer induction cleaning services? I ask because (at least) in the 2018 Optima owner's manual there is no mention of induction cleaning as a required or optional maintenance item; to be clear I am NOT arguing against the merits of whether induction cleaning is *needed* but trying to gather information about it in general, especially given that my car currently has >16K miles on the clock--I did install an OCC at the 2K mile mark.
    Aug 2016
    259
    Quote Originally Posted by tonester View Post
    I'm pretty sure they do... At least, the one I went to did. It stands to reason that any dealer selling GDI engines would also keep the equipment to keep them running in stock, but you would definitely want to call first.
    There are two types of cleaning that I've heard of: Walnut media blasting, and chemical cleaning. Walnut media blasting will do a more thorough job, but the chemicals can work fairly quickly.
    ZER0
    Aug 2016
    259
    Here's a pretty detailed video explaining things:
    ZER0
  1. AutoGuide.com 2018 Car of the Year Award: Watch to Find Out Which Car Wins
    By AutoGuide.com in forum Kia Optima News, Rumors and Updates
    Last Post: 12-20-2017, 01:14 PM
  2. SX struggle starting
    By OptimaPrime215 in forum Engine and Technical Discussion
    Last Post: 12-06-2015, 11:15 PM
  3. Looking for alternate for other car make wheels that I can put on my car.
    By GaryT1947 in forum New Member Introductions
    Last Post: 09-30-2015, 08:00 PM
  4. Locking Doors from outside the Car with the Car on!!!
    By evan42781 in forum 3RD Generation Optima (2011-2015)
    Last Post: 04-20-2012, 05:48 PM
  5. Car guy's with a new car, and over-modifying...
    By cskalski in forum 3RD Generation Optima (2011-2015)
    Last Post: 02-07-2012, 05:05 PM
