Need Suggestions...2012 SX..Eibach lowered..rim size/ tire size
Results 1 to 3 of 3
Thread: Need Suggestions...2012 SX..Eibach lowered..rim size/ tire size
    Learner's Permit OKOptimaSX's Avatar
    Apr 2012
    Broken Arrow, OK
    263
    Gents,
    I need the help of our community. I have decided to keep my 2012 SX and I need input as to how I want to move forward with her in regards to my tire/ wheel situation.
    I had 20" enkei razr's and took them off because the potholes are vicious plus the tire noise was extremely loud. Also, with my ride running the eibach springs I would scrape bottom once in a while therefore I am thinking a taller tire would give me more clearance.
    I want a wheel size/ tire size that will blend in with looks, quietness and have a decent clearance.
    Currently, I am running the stock wheels with eibach spacers (20 mm back and 15 mm front). The sad thing about this is that I have to tighten my lug-nuts every week because the spacers loosen them. It's pretty scary when it happens.
    I know that 19" rims are more expensive due to the odd size. I wonder if I can keep my 20" enkei's and just get different tires that are quieter and don't hit so damn hard as the previous tires. Or I wonder if I should get 18" rims with a taller tire to fill up the wheel-well?
    Any input is greatly appreciated.
    r/
    Marty
    [IMG][/IMG]
    ARK DT-S Exhaust | Eibach Springs | 20" Enkei Wheels | Injen CAI | DRL's | Rear LED running lights | Painted Strut Bar | PIAA Horns | Tinted Windows | Hardmounted Escort 9500ix| K5 sill protectors | Weathertech liners | Custom Polk Audio sound system w/ Infinity head unit | Painted grill, sides and rear spoiler |
    OptimaForums Veteran richysh's Avatar
    Greensboro NC
    2,311
    K5
    SX Prem & Tech
    What torque are you putting your wheels on? I ran 20mm garageline spacers and never had to tighten any lug nuts. And I remember torquing them to 85lbs. And whats the wheel spec and the tire size on your 20s?
    2012 Kia Optima SX Tech & Prem Touring Pkg. Satin Metal/Black 75k miles, purchased 01/07/2012
    - BTRCC 2.0.4 93 Oct Tune
    - SX-L LED DRLs
    - LED switchbacks
    - 28% tint all around, 20% sunroofs
    - Carbon Fiber 3.0 badges
    - Avital 5303L Remote Start
    - Automatic mirror fold module
    - 19" Niche milan m137
    - Nameless downpipe&midpipe
    - HKS SSQV4
    - Custom made intake made by Dysan911
    - D2 Coilovers
    - 14pc stiff rings
    - Red rear LED turn signal with resistors
    - Red footwell LEDs
    - Red painted calipers
    Northeast Ohio
    2,118
    First of all, when running lower profile tires, you'll need to run higher PSI to compensate for the lower air volume of the tire. Oddly enough, running PSI too low will make the tire feel rougher than it would be at the proper PSI.
    Second, you didn't list the size tire you run on your 20" wheels, but the actual wheel assembly could be taller than your stock 18" tires with the stock 225/45R18s mounted. Check it out on a tire size calculator. You're 20" set up could be taller than most 19" tire sizes too. So if it's ground clearance your after but probably not much over your 20" wheels.
    But, you can gain some sidewall with 19" wheels depending and a little bit of overall height over your stock tires. So you can gain a little comfort (especially if you can fit a 245/40R19 on which will require a higher offset wheel with Eibachs).
    ---------- Post added at 03:13 PM ---------- Previous post was at 03:10 PM ----------
    Here is another useful tool for figuring out fit and PSI required for different size tires. I posted it in another thread earlier.
    To get a better idea of different size/rated tires and how much PSI is required, got to Toyo Tire Finderand put your model in. You will get a list of compatible Toyo tires, sizes, load ratings and PSI needed for each tire on your car. You can chose OE or Plus sizes. It's a really handy research tool and you can take what you learn and apply it to any brand tire.
    (When selecting the trim, you'll notice that the SX uses 95V, but the EX uses 93V from the factory.)
    2015 SWP/Black EX Premium with 19x8.5" ET40 Advanti B1 Lupo wheels and
    255/40R19 Bridgestone Potenza RE970AS Pole Position.
    Gone at 92k - 2013 SWP/Gray EX Premium with Megan EZ Street coilovers, 19x8.5" ET40 Advanti B1 Lupo wheels and
    235/40-19 Michelin Primacy MXM4.
    Gone at 68k - 2011 SWP/Gray EX Premium with Eibach springs, 19x8.5" ET40 Advanti B1 Lupo wheels and
    225/40-19 Toyo Proxes 4 Plus tires.
  1. rim size
    By hiway in forum Optima Wheels, Tires and Suspension
    Last Post: 10-26-2014, 04:05 PM
  2. How to down size of house for Mishimoto Baffled Catch Can to size of PCV Valve/Hose
    By ht_addict in forum Optima Engine and Technical Discussion
    Last Post: 06-18-2014, 10:05 PM
  3. SXL Winter Tire Size Suggestions
    By iskortch in forum Optima Wheels, Tires and Suspension
    Last Post: 02-07-2014, 08:49 AM
  4. Best tire size on a 18x7 rim?
    By RSASorento in forum Optima Wheels, Tires and Suspension
    Last Post: 04-27-2012, 10:42 AM
  5. How much can I buy a full size spare with the Pizza Wheel rim?
    By bigpat7676 in forum Optima Wheels, Tires and Suspension
    Last Post: 03-04-2012, 04:47 PM
