[ALL] : Engine Failures - Share Your Experience - Page 32
Page 32 of 35 FirstFirst ... 223031323334 ... LastLast
Results 311 to 320 of 349
Thread: Engine Failures - Share Your Experience
  1. #311
    OptimaForums Veteran carguy75's Avatar
    Lawrenceville,GA.
    1,600
    Quote Originally Posted by CheeseDrink View Post
    Well thought I'd pitch in:
    2012 Optima SX, 65000km
    Injen intake, Warner intercooler, OCC's, BTR tune, turbo-back 3" exhaust
    Cruising at 100km/h at about 2000RPM, engine suddenly started getting a hesitation. Worstened until I reached next gas station, pulled over.
    Turns out a piston ring in Cylinder 2 lost a chunk into the oil pan. No compression.
    The remaining ring chowdered up the bore, so I needed a new short block.
    No warranty, due to the above mods. Additionally, since the failure came neither from oil starvation or the bearing issues, they couldn't swing a claim for me.
    Ended up sourcing a used 2014 engine from a wreck with 24,000km on it.
    Engine + labour for KIA to install was about $5000 all in.
    I believe the problem to have lied with the exhaust, as the engine was prone to over-boost conditions with the less restrictive exhaust. I was actually running about 2-3psi more boost than I thought, so it was probably a failure from that + high compression? Who knows. Stock exhaust is back on and no problems since.
    Lessons learned! Pictures here: Engine Replacement 2017 - Album on Imgur
    That sucks that your engine failed and you have to pay out of pocket to replace it.
    It sounds like you have this engine maxed out power wise.
    You must have been making well over 300hp on stock 2.0 turbo engine, however KIA did not build these engine to handle that kind of power for longevity like Mitsubishi did with the twin version of this engine in the EVO.
    2-3 psi of extra boost equals to about 20 or more horsepower plus extra heat and stress on the engine.
    The engine bearings can barely hold up in stock form with the marginal maintenance requirements specified by KIA.
    I can imagine how the rest of the engine handles been pushed pass it limits like in your situation with over boosting and power mods.
    2014 Black KIA Optima SXL loaded w/
    AEM dry performance drop-in air filter w/radiator cowl panel removed
    Hella yellow HID look H7 high beam light bulbs
    Running only Shell V-power 93 octane gas
    5w-40 Total Quartz 9000 Energy synthetic oil
    NGK ILKR8E6 spark plugs(1422)
    Bosch Icon wiper blades- 24A, 18A
    Black check-mark fog light trim
    Michelin Primacy MXM4 225/45-18 tires
    Hawk HPS 5.0 Front brake pads HB661B.667
    Centric Posi Quiet Ceramic Rear brake pads 105.15440
  3. #312
    44
    Kia Optima
    2012 SX
    Quote Originally Posted by carguy75 View Post
    Yep, was putting down 280hp/325lb-ft at the wheels. So maybe like 325/350 crank? Shame the piston rings were the weakest link!
  4. #313
    Newbie ejgss2001's Avatar
    Jun 2011
    Pennsylvania
    8
    Another one down....
    2011 EX (non-turbo)
    83,000 miles (original owner)
    Driving along at 50 MPH, engine started hesitating before losing power. Never stalled. During tows, car started right away but was knocking like crazy.
    Had to authorize dealer to drop oil pan. One day later was informed KIA would warranty a new engine, but I was never given a diagnosis.
    Car was maintained a private garage (I gave copies of all receipts to dealer when the car was towed)
    KIA did not approve rental/loaner
    Due to pick up car this afternoon (at dealer since Friday 3/10).
    A relative had the engine in his 2014 non-turbo EX replaced last year at 14,000 miles under warranty. In his case, the issue was a sporadic oil light, though level was fine. Dealer contacted KIA who directed some teardown investigation before sending replacement engine. That dealer provided a loaner.
  6. #314
    Jun 2016
    58
    2013 SXL
    Seems like the BTR tune was the main factor. do you agree?
    ---------- Post added at 02:22 PM ---------- Previous post was at 02:19 PM ----------
    Wouldn't the 3' exhaust (with it being less restrictive than say 2.25/2.5) be a good thing for over boost?
  7. #315
    Mar 2017
    4
    Long post. Sorry......
    My mom bought a new Optima EX 2.4L back in 2012. Up until now, she has loved the car. She went from a BMW to this and was impressed with what she got for the money.
    Fast forward to Tuesday, March 14, 2017, she was driving about 20 mph in traffic and the engine died. No odd noises, check engine light, etc.. Just died. She tried to restart it, but got nothing. She also told me that she saw a small amount of smoke coming from under the hood, and smelled an electrical smell.
    After some googling, I found this site and saw that many others experienced this same problem. Seized engine. She had it towed to the dealership and got a rental that Tuesday night.
    Her car had 56,000 miles on it after about four years and eight months of owning it. She was still within the 5 year, 60K bumper to bumper. She got a call the next day (Wednesday) from Kia who said the engine was seized, the starter was fried, and they would open a ticket with Kia to see if it would be covered. She changed the oil every 3k miles, but not at a Kia dealership. Later that afternoon, she got another call saying the warranty replacement was approved and the long block would be there the next day (Thursday). The long block arrived the next day and she was told her car would be done the following day (Friday).
    Sure enough, Kia called her on Friday morning telling her the car was done. They replaced the long block, starter, and intake manifold (per the invoice, due to metal shavings in the oil pan), all under warranty. I don't know what the shavings in the oil pan would have to do with the intake manifold, but obviously we're not complaining. Maybe because the PCV system could have circulated metal debris into it? I'm sure there was a good amount of carbon buildup in it anyway.
    They also replaced the ECU under some service campaign. I couldn't believe that her warranty claim took less than 72 hours from tow to dealership to her picking it up. That was amazing. They also covered the rental charges (as they should have).
    What surprised me was that they did not request oil change/maintenance receipts. It didn't matter as she had them; I was just surprised they didn't ask.
    I am now on my third Coyote Mustang, and when the Coyotes fail, warranty claims usually take around three weeks (if covered at all. Most Coyotes that fail are tuned, and therefore, have the warranty voided.)
    Now on to my question- have the replacement long blocks been revised to stop this from happening in the future? If not, she will probably trade it in. She just won't feel comfortable keeping it if that could essentially happen again at any time with no warning.
    Thanks, and sorry again for the long post. I created a new thread in this subforum for this, but it isn't showing up. Sorry if this is a duplicate.
  8. The Following User Says Kudos to daustin For This Useful Post:
  9. #316
    Mar 2017
    Upstate, NY
    Another one bites the dust....
    Year: 2012, Make: Kia, Model: Optima, Trim: SX
    - Engine/Performance Mods: None
    - Mileage at the time of failure: 96k (edited from 86k, typo)
    - Determined cause of engine failure: Rod bearing failure, metal shavings in oil pan
    - Was proper maintenance performed? Oil/filter every 3k miles, without fail
    - Was it covered under warranty? Update: Yes
    - Did KIA approve car rental/reimbursement? Update: Yes
    - What was the outcome? Update: Replacing with brand new engine, NOT a re-manufactured one, according to service manager.
    100% stock, no mods
    Heading home from work on Thursday 3/23, no sign of any issues until I noticed a slight lack of power trying to pass someone on the highway about 5 minutes before my exit. As the engine revved down on the off-ramp, I heard the dreaded knocking. Accelerating from the stop light at the end off the off-ramp brought a loud knocking, increasing with RPM. Luckily it did not seize, and I was able to make it back to my driveway, although it did stall twice before I got home. Pulled over and was able to re-start, each time the noise getting worse.
    I immediately called the dealership and told them I would be having it towed in that evening. Next day, I got a call from the service center at my dealership asking for maintenance records, which I don't have other than oil receipts. Service tech told me to not even bother with the receipts, and that he would submit a claim anyway. Dealer will not issue loaner or rental until claim is approved, which is a bummer, but understandable. He also advised me to call Kia and file my own claim, which I did. They apparently diagnosed the issue and submitted the claim without taking the engine apart, which I thought was odd. I figured corporate would want at least some evidence.. Anyway, hoping the claim goes thru with no trouble as has been the case with many of the previous posters in this thread.When I learn more, I will update.
  10. #317
    Mar 2017
    Upstate, NY
    Quote Originally Posted by btrips77 View Post
    100% stock, no mods
    Update: Heard back from corporate today. My rep received photos from dealer showing that the engine was, in her words, "very clean" which I had suspected would be the case. The rep told me that the motor will "in all likelihood" be warrantied. Mind you, I submitted ZERO maintenance records. Glad Kia is owning up and taking responsibility for this problem, though the lawsuits obviously are forcing their hand somewhat.
    On a less encouraging note, the rep implied that they are technically not required to provide a loaner/rental, so that may be something I have to work out individually with my dealership. Has anyone else had trouble obtaining a loaner or rental from their dealer during warranty repair?
  11. The Following 2 Users Say Kudos to btrips77 For This Useful Post:
  12. #318
    OptimaForums Veteran SXexcess's Avatar
    Feb 2012
    ABQ, NM, USA
    1,129
    Looks like they are just looking to see if the oil has been changed regularly by inspecting for sludge. Some folks aren't so good at maintenance...
    2012 Optima SX w/ premium touring & tech packages, Corsa Blue, born in the USA Jan 24 2012, bought Feb 11 2012 w/7 miles
    Mods; 15% tint all around, clear bra, dechromed/body color grill, blue brake calipers, plastidip'd emblems, dark tint window vent visors, painted the badge T grass green (T-GDI), Fumoto oil drain valve, yellow tint fogs, mud guards, General Altimax RT43 225/50/18 tires and full size spare
    http://smg.photobucket.com/albums/v6...20Optima%20SX/
  13. #319
    Mar 2017
    Upstate, NY
    My claim was approved today. I was indeed provided with a free rental as the dealer was out of loaners. New short block has been ordered, but the dealership unfortunately could not give me an estimate on how long it will be as they have at least one other Optima in for engine replacement before they get to mine, and they have to prioritize the shorter daily service appointments, which is totally understandable.
    I couldn't be more happy with the service I have received both from the KIA corporate rep handling my case. My dealership.. well that's an entirely different story.. They tried scamming me for new rotors on both axles, which I know for a fact are fine, as well as a transmission fluid flush. They also said that they would have to charge me to change the steering mode setting, which frankly is ludicrous.
  14. The Following User Says Kudos to btrips77 For This Useful Post:
  15. #320
    NY
    1,119
    Optima-Black
    SX-T Prem/Tech
    IMPORTANT - READ THIS IF YOUR DEALER TRIES TO DENY YOUR ENGINE REPLACEMENT DUE TO LACK OF MAINTENANCE RECORDS:
    Read this document and show it to the Dealer who is scrutinizing whether or not you have maintenance records after being diagnosed with an Engine Failure.
    Go to October 21, 2016 specifically where KMA states that approval for engine failure replacement must not be based on maintenance record history or lack of proof.
    http://redirect.viglink.com/?format=...303.1491557158
  16. The Following User Says Kudos to toptobottom For This Useful Post:
  17. Remove Advertisements
  1. How many high-milage (80k+) Optimas out there? (curious because of engine failures)
    By Dollarsignrack in forum Optima Engine and Technical Discussion
    Last Post: 06-04-2017, 04:45 PM
  2. [ALL] : Sonata 2.0T and 2.4L engine failures (Huge Recall by Hyundai)...
    By williamhood in forum Optima Engine and Technical Discussion
    Last Post: 12-15-2015, 10:07 AM
  3. 2012 Sonatas engine failures...
    By cwoptima11 in forum Optima General Discussion
    Last Post: 12-07-2015, 09:29 PM
  4. 2011 Sonata Engine Failures- Big problems...should we worry?
    Last Post: 12-07-2015, 07:04 PM
  5. Replies: 3
    Last Post: 03-08-2012, 09:50 PM
