Broken front camera. Has anybody replaced it yet? - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Broken front camera. Has anybody replaced it yet?
    1,225
    If you entirely removed the "lens" part that is cracked, would the image still be in focus? If so, then the cracked part is not a lens, but just a transparent dust cover or protector, and is not critical to focusing the image, so you can just remove it and replace it with anything transparent (and use silicone or adhesive to seal it up and keep the dirt/moisture out).
    Look, here is what you can get for under $14 on ebay! Just might be worth the risk - if it doesn't work, then you wasted only $14 and can then proceed to spend the $700 or whatever to replace the entire camera:
    Universal 8in1 Clip On Camera Lens Kit Fisheye +Wide Angle +Macro for Cell Phone | eBay
    So you would just find which of those little circular covers is the closest match and use it to replace your cracked one. Normally I'd say replace your entire camera, but the price is, well, seems like an injustice against humanity to charge that much for a simple camera.
    May 2016
    134
    SX-L
    You'll need to find the specs on the OE lens before trying to replace the lens. There are a lot of factors with optics that are unknown with that lens. Majority of these cameras have threaded housings making the lens replaceable, a few are molded into the case or glued
    Apr 2017
    El Paso, TX
    30
    2016 Optima SXL
    The first thing we need to do here, to stop speculation, is to unscrew and remove whatever is threaded on the camera base. There're 2 squared holes 180º apart (take a look at any of your cameras -all are the same), and you'll see what I'm talking about. Maybe the whole camera comes out. If that's the case, no fix possible. But if only the little cover comes out, and the camera still works, then it'd be possible to just change that little part, and keep looking into this. Anybody can try that. I first need to find a suitable made-up tool as not to screw anything up. I'll also try a pair of pliers I have to remove circlips; maybe I can use those to try to unscrew that part (whatever it is).
    2016 Optima SXL white/white. MODS: chrome wheels, Homelink, cargo hook, cargo mat, tinted windows (35%).
  1. [SX] Replaced front brakes with R1 Concepts slotted rotors
    By strider5 in forum Optima Engine and Technical Discussion
    Last Post: 09-03-2016, 12:47 PM
  2. Adding Rear View mirror Backup LCD + Adding a Front Facing Camera
    By jery911 in forum Entertainment: Audio, Navigation, and Electronics
    Last Post: 07-08-2016, 02:15 AM
  3. tranny being replaced
    By jamesbaker1975 in forum Optima Engine and Technical Discussion
    Last Post: 05-27-2015, 11:55 AM
  4. [FS] : SOLD Sony Nex-3 Camera (Compact Interchangeable Lens Camera)
    By titaztik in forum Classified Forum
    Last Post: 04-17-2013, 11:11 AM
  5. Help.. Does my tire need to be replaced?
    By DramaLLama in forum Optima Wheels, Tires and Suspension
    Last Post: 02-20-2013, 10:13 AM
