Replace 2012 OEM Nav with Afternarket headunit
Results 1 to 10 of 10
Thread: Replace 2012 OEM Nav with Afternarket headunit
    May 2017
    Optima 2012 My13
    Platinum
    Have seen similar posts but nothing that really addresses my issue. Can it be done and what happens with the climate/ac controls? I saw a thread from a user I think called ACE who was working on a project to address this but nothing came from it. Also idatalink don't seem to have anything for Kia either. So has anyone been able to do this?
    Aug 2016
    19
    Go to metraonline.com and follow the what fits my car drop down menu and get the dash, harness, antenna adapter and metra axxess steering wheel adapter info and ebay/amazon them. You can order a standard non nav hvac control on ebay from LKQ parts fro about 40-50 shipped. Plugs directly in. One plug left over that goes to the radio for control and image. Tuck away as it will not be used. Installed mine in about an hour. Pioneer NEX units offer best features and phone control for dollar. If you want video you will need to order a bypass module/chip.
    May 2017
    Optima 2012 My13
    Platinum
    Cheers Ron. Will check it out and see how it goes.
    May 2017
    Optima 2012 My13
    Platinum
    So I spoke to Sean from Metra and he said they don't make facsic kits for right hand side vehicles. He also said that they don't even have a solution for retaining the climate controls on the display.
    So is there any solution at all??
    Dec 2015
    South Central
    633
    Quote Originally Posted by Achandab View Post
    Nope, unfortunately no company makes any fancy harnesses and modules for our kias. I've done a lot of research.
    May 2017
    Optima 2012 My13
    Platinum
    Cheers for that Jery. I thought that might be the case. I've researched quite a bit myself and will now decide to give up. However i would still like to know if it's possible to play video via the aux in port or any other method in the factory OEM. Has anyone found a way to do this?
    Dec 2015
    South Central
    633
    I mean it is possible, but not via the aux port. One way of doing it is connecting the video on the camera port on the back of the headunit. But when you do that your going to have two issues. 1: you have to trick the factory screen to think it's in reverse or else it's only going to work in reverse. 2: your goring to have the parking lines on screen all the time.
    At the end it's not really worth it, At least to me. If you really want video playback on your stereo just go after market stereo. And convert your climate control to the physical buttons. It's been done before.
    May 2017
    Optima 2012 My13
    Platinum
    cheers mate. I thought of that as an option going the physical climate control route. But seems like a step back. Is there a post or tutorial from someone who has done this?
    Dec 2015
    South Central
    633
    I don't really see it as a step back.
    But here's the link Help installing new head unit in 2011 Optima with Nav + Infinity - UPDATE: installed!
    May 2017
    Optima 2012 My13
    Platinum
    Cheers Jery. I'll check it out. Thanks
  1. [EX] : 2011 stock nav headunit Bluetooth & voice recognition issue
    By CubanLorenzo in forum Entertainment: Audio, Navigation, and Electronics
    Last Post: 02-03-2016, 10:48 AM
  2. OEM Nav Wiring Diagram
    By nt75 in forum Entertainment: Audio, Navigation, and Electronics
    Last Post: 07-03-2013, 03:31 AM
  3. OEM unit AND Nav mod
    By MoPho in forum Entertainment: Audio, Navigation, and Electronics
    Last Post: 03-13-2013, 10:10 PM
  4. Need to replace my bulb in my fog light on Optima 2012
    By bigpat7676 in forum Optima DIY
    Last Post: 12-30-2012, 04:50 PM
