sub install question - tapping rear speaker wires at B-Pillar?
Results 1 to 2 of 2
Thread: sub install question - tapping rear speaker wires at B-Pillar?
    Mar 2013
    Pittsburgh
    14
    in an effort to avoid taking the dash apart to get tothe back of the stereo - how hard is it to get to the rear speaker wires at the B-Pillar? I have a small class D sony amp (4x50) which i will run in a 3 channel config with 100W going to a 4ohm sub running free air, and will power the rear doors off the same unit. This simplifies my issue with needing to lower sub output without putting in an in-line attenuator so my wife won't flip out every time she's in the car (just fade the stereo to front. The amp has high level inputs built in, which keeps me from having to run RCA's to the front of the car (sure wish Kia had put in some 6x9's on the back deck...would have made life SO much easier )
    Yes, i searched, and nothing came up with the time i was able to put in from work. I know i need to run a power cable but this path looks pretty clear to the passenger firewall and there are a number of grommets to go thru. Please keep in mind - i'm not your normal run of the mill novice, i'm just lazy in my old age and I still like my tunes. this stereo NEEDS some low end DESPERATELY. I worked at a local sound shop for about 8 years many moons ago and built a CRX that ran flat RTA with 138db...i can do this stuff...i just don't want to HACK this car...i'm a family man now
    OptimaForums Veteran nappydrew's Avatar
    Jan 2013
    Corpus Christi, TX
    1,659
    It's not hard to get to them at all, they run right under the kick plates, but identification of the wires can be a bit more tedious, as there are a metric $h!+ ton of wires in that bundle.
  4. Remove Advertisements
  1. Door speaker install
    By The_l3est in forum Entertainment: Audio, Navigation, and Electronics
    Last Post: 07-11-2014, 10:25 PM
  2. where to "snag" the reverse wire and brake wires for aftermarket head unit install
    By anomaly65 in forum Entertainment: Audio, Navigation, and Electronics
    Last Post: 07-02-2014, 11:05 PM
  3. [LX] : Tapping into back speakers with sub - remote wire question??
    By autumneffect in forum Entertainment: Audio, Navigation, and Electronics
    Last Post: 03-05-2013, 10:17 PM
  4. Identifying the rear turn signal wires
    By 11snowwhitesx in forum Entertainment: Audio, Navigation, and Electronics
    Last Post: 11-06-2012, 03:38 AM
  5. speaker install
    Last Post: 10-09-2012, 09:19 AM
