[VENDOR][FS]: TruHart Optima/Sonata Sport Shocks/Struts Combo - K5 Optima Store - Page 37
Page 37 of 40 FirstFirst ... 273536373839 ... LastLast
Results 361 to 370 of 396
Thread: TruHart Optima/Sonata Sport Shocks/Struts Combo - K5 Optima Store
  1. #361
    Riding Lawn Mower rhamej's Avatar
    May 2016
    Tennessee
    94
    Quote Originally Posted by ricardoreyna View Post
    so you still bottom out even with the truharts?
    Yes.
    ---------- Post added at 07:46 PM ---------- Previous post was at 07:41 PM ----------
    Quote Originally Posted by Blackpearl View Post
    Very interesting. Wonder if I would have a problem with the 38 offset.
    If you go with 38 offset, I'd go with 235/35 tires. But then you will sacrifice some comfort having a shorter sidewall. Honestly, I'm probably not the best source for all this. This is the first time I've done something like this to a car other than wheels and tires and minor cosmetic stuff. Never dealt with lowering before.
    ---------- Post added at 07:54 PM ---------- Previous post was at 07:46 PM ----------
    Update about the fender liner from the dealer. The 18" liner is the one I have on my car. So when I got home I jacked it up and took out the heat gun. I was able to push it up and mold it really easy. The only spot I couldn't mold was the part right around the screw towards the front. It baaaaarely rubs now on hard hits. I will have to live with it I guess till that little part just rubs away. Or when I go back to the shop for an alignment update I'll add a little more negative camber. Meh, I'm done messing with it for now. It's taking up to much of my time.
  3. #362
    Sep 2015
    Clearwater, FL
    356
    K5 SXL
    Quote Originally Posted by rhamej View Post
    Yes.
    OK I get ya. I'll figure this one out. I might even stay with 18" wheels. There cheaper and so are the tires.
  4. #363
    May 2016
    Tennessee
    94
    19x8's would be fine if you want to go with 19's. You are only talking 1/2 inch. 1/4 inch a side. You could definitely go with 235/40's and have no issues I bet. The rub on mine is actually the width, not the height. If the tire was a 1/4 inch more inset into the wheel well, all would be fine. I bet I wouldn't even have had to roll the fenders or have negative camber. I am going to attempt one more fix later today to get rid of that spot around the screw. Will report back later.
  5. #364
    Sep 2015
    Clearwater, FL
    356
    K5 SXL
    The wheels I'm getting are 19x8.5. I either want to do a 235/35/19 or a 245/35/19
  6. #365
    May 2016
    Tennessee
    94
    38 offset? I'd go with the 235/35/19 just to be safe then. With a 38 offset your wheel will poke more than my 40 offset.
  7. #366
    Sep 2015
    Clearwater, FL
    356
    K5 SXL
    What about a 235/40/19?
  8. #367
    May 2016
    Tennessee
    94
    It would very close on my car with a 38 offset. Hard to tell.
    Update on mine. Finally, no more rubbing! Took a dremel to the fender liner on the inside corner of that screw right where the bumper meets the fender. All good now. And I didn't have to dremel much at all. Hit the big dips and nothing! Man, glad that's over now.
  9. #368
    Learner's Permit audiorage22's Avatar
    Oct 2016
    Los Angeles
    124
    Optima Hybrid
    Optima Hybrid
    How low is the drop with the Eibach springs? I'm on truhart and I believe it's 1.6 on the rear and 1.5 in the front. Eibach must be lower for you to have been rubbing with a 40 offset.
  10. #369
    Sep 2015
    Clearwater, FL
    356
    K5 SXL
    Quote Originally Posted by audiorage22 View Post
    Did you get the Tru Spring option that comes with the struts? What's your fender height from the ground? And do you have aftermarket wheels? If so what size and offset? Thanks
  11. #370
    Oct 2016
    Los Angeles
    124
    Optima Hybrid
    Optima Hybrid
    I did get the TruHart Springs as well. I'm using aftermarket 19x8.5 +38 offset. I don't know the fender height from the ground off hand. I used CARid to buy the wheels and tires and a reputable custom shop to do the install of both the suspension and wheels. The tech told me he had no trouble with alignment or rubbing.
  12. Remove Advertisements
  1. [VENDOR][FS]: 2011-2015 Kia Optima Complete Combo LED Package - K5 Optima Store
    By K5 Optima Store in forum K5OS - LED & HID Lighting
    Last Post: 11-18-2016, 11:18 PM
  2. 03 optima rear shocks/struts
    By furyfrank in forum Optima Wheels, Tires and Suspension
    Last Post: 07-28-2015, 03:33 PM
  3. [VENDOR][FS]: 2011-2015 Kia Optima Complete Combo LED Package - K5 Optima Store
    By K5 Optima Store in forum K5 Optima Store
    Last Post: 01-09-2015, 05:38 PM
