2011 kia optima sx LED door handles - Page 4
  1. Welcome to Kia Optima Forums : 2011 Kia Optima Forum – General discussion forum for Kia Optima
    Welcome to Kia Optima Forums : 2011 Kia Optima Forum - a website dedicated to all things Kia Optima.
    You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, Join Kia Optima Forums : 2011 Kia Optima Forum today!
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 57
Thread: 2011 kia optima sx LED door handles
  1. #31
    Member
    Apr 2011
    Orlando, FL
    34
    Which wire did you tap into to get the walk up mode to work? Also do you have a step by step guide
    Car History
    11' Corsa-Blue Optima SX 2011-present
    06' Gray Mustang GT 2007-2011
    98' Silver Mustang GT 2001-2007
    83' Midnight Blue F150 XLT 1996-2001
  3. #32
    Shuttle Driver
    Jun 2011
    522
    You HAVE to tap at the bulbs themselves (or their contacts obviously) in the panel. There is no other way to do it. Got out my multimeter and was doing some wiring in there so I figured I'd run some wire for when I do this mod. Soldered a positive wire and a negative wire onto the bulb contact patch leads... hard to describe. I can post pics when I do this mod. I took plenty.
    BTW the reason you have to do it this way is because Kia uses a switched ground rather than a switched positive (like BMW does) for their courtesy lighting. Even the scuff plate "Kia" lighting is done this way. I tried a ton of different wires to avoid tapping at the dome light... no luck.
  4. #33
    Driver's License BERTO1230781's Avatar
    Jan 2011
    Charlotte, NC
    301
    yeah just like crystal said it's kinda hard to find the right wire for the leds to dim like the interior lights. if i remember i tap to one side of the dome light switch and then tap into the positive side on the dome light itself this way your leds on the doors handle will light up when u approach the car and when u open the door and dim with the rest of the lights. this way also when u turn on the dome light in the car the leds WON'T turn on. the way i did it was used a multi tester when i found the wires i needed in this case the contacts i used an led and touched the contacts to see if it's the affect i wanted and after that solder your wires and your done with the dome light. just take your time with the handles taking then aparts they are kind hard at first but after u do one the rest are easy.
  5. #34
    Shuttle Driver
    Jun 2011
    522
    ^ I'll haved to check again because i'd rather it not come on all the time with the domes. Was it the yllow/black wire u tapped?
  6. #35
    Jan 2011
    Charlotte, NC
    301
    no i took the dome light out and soldered directly to the path ways of the switch and soldered the positive to the positive side of the light bulb this way it DOESN'T come on when u turn on the dome light. don.'t remember witch contacts i solder to ont eh switch but u can always use an extra led and put the positive side on the dome light light bulb and touch the negative side to the switch u will see the path ways i believe looking from the top it was the left side of the switch i solder too. just use a soldering iron to melt back the plastic to have more of a soldering surface.
  7. #36
    Junior Member
    Nov 2011
    20
    Dude, you need to write a mod book, listing all you mods. I will bet there are a bunch of people who would pay you for your mods. They would probabky pay even more if you could do them.
  8. #37
    Member
    44
    dumb question sorry: Is there plug and play version of this mod that doesn't require soldering/cutting of wires? Possibly just installation of new door handles?
  9. #38
    Jan 2011
    Charlotte, NC
    301
    No not yet our cars doesn't have the proper harness for the door handles of the k5 for it to be a plug and play. U have to do everything from scratch.
  10. #39
    Moderator guardiannite's Avatar
    Clovis, NM
    729
    There any way we can get a DIY and a link to the parts used for this mod. THX
    • 2012 Kia Optima SX Spicy Red with Premium Package
    • 20in Nurburgrins Rims with Falken FK-452 Series Tires
    • 30% Front 20% Rest SunTek High Performance Window Tint
    • Re-Badge with Luxury Edition Emblems
    • Upgraded Mood Lights
    • LED Cup Holders
    • Remote Start using EVO-ALL and Python 1401 using Factory Fob
    • Rubber Seal At Front Doors
    • ​Nameless Performance Intake / Charge Pipe
    • Grounding Kit
    • Strut Bar
  11. #40
    Clovis, NM
    729
    Berto will this work? http://www.ebay.com/itm/10-PCS-LED-5...#ht_784wt_1163
    also do I need to buy wire aswell to hook it all up?
    • LED Cup Holders
    • Grounding Kit
    • Strut Bar
  12. Remove Advertisements
Quick Reply Quick Reply
Register Now
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
  1. Chrome Door handles
    By VAoptima in forum Optima Appearance and Body Modifications
    Last Post: 09-15-2011, 11:14 PM
  2. Chrome Interior Door Handles Available?
    By Bayou_Flyer in forum Optima Appearance and Body Modifications
    Last Post: 07-04-2011, 07:32 PM
  3. 2011 Kia Optima K5 Chrome Door Pillars
    By OptimaKing in forum Optima Appearance and Body Modifications
    Last Post: 06-16-2011, 08:55 AM
  4. 2011 Optima front door mood lights
    By Dohmaster in forum Optima General Discussion
    Last Post: 05-24-2011, 09:34 AM
  5. site for door handles etc
    By linsfreak in forum Optima DIY
    Last Post: 04-19-2011, 12:10 AM
