Interior dome light cover
Results 1 to 10 of 18
Thread: Interior dome light cover
    Nov 2011
    19
    I can't seem to find any thread regarding removing the dome and map light covers. I just received my LEDs but do not want to damage the covers. Does it snap off? If it does, from the clear cover or the plastic molding? Any assistance would be greatly appreciated. Thanks in advance.
    OptimaForums Veteran
    Apr 2011
    Elkton, VA
    1,568
    Hope this is what you're looking for.
    Removal
    Room Lamp
    1.Disconnect the negative(-) battery terminal.
    2.Carefully remove the lamp lens (A) from the room lamp with a flat-tip screwdriver.
    Take care not to damage the part (B)
    [A type]
    [B type]
    3.Replace the bulbs (A) and remove the screws if it is necessary.
    4.Remove the room lamp assembly (A) after disconnecting the connector (B).
    Vanity Lamp
    1.Disconnect the negative (-) battery terminal.
    2.Remove the vanity lamp (A) by pressing the clip (B) with a small screwdriver.
    3.Remove the vanity lamp assembly after disconnecting the connector.
    Nov 2011
    19
    Thanks!!!
  5. #4
    Shuttle Driver Silver1stBuy's Avatar
    Aug 2011
    La Porte, TX
    575
    Sorry to be a heckler but is it just me or do none of these look like our lights?
    Do the interior lights differ by trim?
    ___SOLD - 2011 Optima LX Bright Silver Metallic, Convenience Package w/Remote Start___
    ___PURCHASED - 2014 Mustang V6 Oxford White, 6-speed Manual Transmission___
  6. #5
    Learner's Permit Socalman's Avatar
    Sep 2011
    Northridge ca
    111
    I think it's meant as a general idea of how to pry off the lights some (like the maps) only need tohave the lens taken off but the vanity's you take out the whole assebmbly. For the rears i just did the lenses. I like how it does show the different housings for the lights. On the sunroof models the room lamps take a festoon type bulb same for the glove compartment. I swapped out the reg bulbs for LED's and like the color white. Did the trunk and glovebox with same white LED's what a difference. Now if I can just figure out which bulb is for the vanities i'm all set. but i'm really itching to get this set up.......LED Rear Bumper Reflector Light Lamp Set for 11+ Optima | eBay I just don't know about pulling off the bumper but boy would that enhance the rear end look if I can get it done.
    2013 EX Remington Red with Premium and Tech Interior L.E.D.S. 6000K H.I.D.'s front hi/lo Cree fog lamps LED bumper and tails. Rear license plate L.E.D's Cree back up LED's.
    Optima LED "K5" LOGO Light Projector Set Reverse mirror tilt switch back l.e.d turn signals and upgraded horn from K-5 Optima Store. Work it David!
  7. #6
    Feb 2012
    Redondo Beach, Ca
    57
    Does anyone know how the dome light covers come off for the SX with sun roof? Front and rear? Everything I read is that they just "pop" off but I tried to get them off using a small jewelers screwdriver and all that is happening is the grey plastic around the lens is distorting and the lens isn't coming off. So I quit before I F*ck everything up just trying to get the lens off.
    Ok found the info:
    On your interior lights, map and dome, on the opposite end of that you push to turn the lights on (the end that doesn't move) insert a business card between the between the light lens and the frame, next to the business card insert a very thin flat bladed screwdriver and pry the lens down and away from the frame. it' will pop loose.. do it on both sides and the lens will fall out.
    Thanks go to: 2012SXDave
  8. #7
    OptimaForums Veteran Jhall520's Avatar
    Sep 2011
    Mundelein, Illinois
    3,098
    Are you using the screwdriver on the tabs that are shown above?? If not, the plastic will flex.
    JHall520's Showroom
    2013 2.0L SX Ebony Black
  9. #8
    Learner's Permit K5 Royalty's Avatar
    Bay Area, CA
    273
    Captian Obvious here. Read your manual, it tells you where to pry.
  10. #9
    Feb 2012
    Redondo Beach, Ca
    57
    My lenses dont look like any of the pictures above. I have the SX with sun roof. They look sort of like the "Type A"
  11. #10
    Feb 2012
    Redondo Beach, Ca
    57
    Quote Originally Posted by K5 Royalty View Post
    I already looked at the manual. My manual says to pop the lens off. And there are some pictures and that is it Thanks for the help
  12. Remove Advertisements
  1. Courtesy Door light cover
    By dopey3822 in forum Optima DIY
    Last Post: 01-23-2014, 05:51 PM
  2. Car cover
    By RedDog in forum Optima General Discussion
    Last Post: 10-10-2012, 03:39 PM
  3. back seat cover?
    By novanosis in forum Optima Appearance and Body Modifications
    Last Post: 08-09-2011, 12:56 PM
  4. Engine cover removal
    By philbytx in forum Optima Engine and Technical Discussion
    Last Post: 06-20-2011, 05:30 PM
